Places to look for cause of low MPGs
Old 04-19-2012, 04:48 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Originally Posted by A/Ox4
Neither one is used to determine proper fuel atomization. Either one can be with in spec and you can still have poor atomization.
I recommend Fuel PSI in cab as the 4th gauge.
...better to spend the money on a Auto Enginuity software package, no?
Is fuel pressure goes down on the guage what the heck are you gonna do?...wonder if the gage is working correctly! ha!
  #122
Old 04-19-2012, 05:07 PM
JT250's Avatar
JT250
JT250 is offline
AE can be very helpful. If the gauge shows low fuel pressure you know you have a clog or a kink or your fuel pressure regulator is bad. Gauges just tell you that there is a problem then you have to figure out what it is.
  #123
Old 04-20-2012, 02:16 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
[quote=JT250;11725797]
Yes I have checked m odo as well. It I good.
quote]
I assume yourve seen this? http://oregonfuelinjection.com/pdf/f...diagnostic.pdf
  #124
Old 04-20-2012, 02:20 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Get both, ideally.
If fuel pressure goes down it can mean a few things. If it is prefilter, then it is one of two things. If it is a gradual drop, its time for a new pump, a sudden drop would mean a clogged line or screen. Post filter just adds changing the fuel filter to that list.
7.3L PSD - How To: Measure Fuel Pressure - YouTube
  #125
Old 04-20-2012, 02:46 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Thanks for the video A/Ox4.
So I need a fuel injection pressure tester up tp 100psi and adaptors.
My fuel filter/water separator has 10,000 miles on it...so its time for a change, no?
Can you direct me to the specific fittings I need for the post and pre filter locations on the fuel bowl?
  #126
Old 04-20-2012, 02:49 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I change my filter every 15,000 miles. The links to what you need to measure fuel pressure are in the description of the video, but you can get them here:
Replacement O-rings for Ford Diesel Engines
  #127
Old 04-20-2012, 03:02 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Thanks so much.
I dont see any links in the video.
But the prices for those NPT adaptors are a little nutty once you factor in shipping.
You an get an entire kit for $45. http://www.amazon.com/Actron-CP7838-...4951782&sr=8-1
  #128
Old 04-20-2012, 03:20 PM
JT250's Avatar
JT250
JT250 is offline
Thanks so much.
Ive got like 30 in my kit. The info is in one pf the links I posted earlier. If you don't have a harbor freight near you, you can order online. The fitting
Can be purchases at home depot Lowes or ace
  #129
Old 05-07-2012, 02:28 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Hey JT250,
What about if your trip odometer is faulty? That would cause a miscalculation of MPG. You would obvioulsy catch a huge error but a more subtle one might be caused by an erroneous odometer.
Reason I thought of that was because I went to check my MPG when I filled up yesterday (20 gallons) and my trip odometer read 55 miles! WHAT! So I immediately realized that I had pulled the batteries that same day. It must have set the trip to ZERO (or I am getting 3 MPG! OUCH).
Then I realized something else....my speedometer jumps around at 55+ (which makes the cruise control worthless).... and if the speedometer is tied to the odometer, (I dont think it would be) then I am getting incorrect mileage on odometer and trip odometer.
Thoughts?
  #130
Old 05-07-2012, 02:37 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Yes, ODO inaccuracies will cause incorrect MPG calculations. For example, my tires are 3% larger than the stock tires, so my ODO is 3% off. Which way? I dont know because I never took the time to care. But I DO know that all of my MPG readings are also 3% off.
  #131
Old 05-07-2012, 02:41 PM
JT250's Avatar
JT250
JT250 is offline
I think I have compared with GPS before and it is good but I will g compare it to Garmin and my phone to be sure. I'm going to play with my fuel pressure on Wednesday it is 72psi right now at idle.
  #132
Old 05-07-2012, 02:44 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
So are you guys implying that the speedometer and odometer are connected? My bad speedometer is resulting in an incorrect odometer reading????
  #133
Old 05-07-2012, 03:10 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Yes they both use the speedo sensor mounted atop the rear differential.
  #134
Old 05-07-2012, 03:11 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
However, one can fail independently of the other. Your speedo can break and your ODO be fine. But if the computer is incorrectly calibrated they will both be off
  #135
Old 05-07-2012, 03:38 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Holy smokes!
...I hope the odometer is registering the correct total mileage! Damned the speedometer. I gotta check this with Garmin.
A/Ox4
56
12-05-2021 11:36 AM
levimorris85
Texas Chapter
07-17-2017 03:50 PM
harley4jcs
Modular V10 (6.8l)
11-27-2015 03:32 PM
Diablo540
29
01-21-2014 02:09 PM
mecanto
1999 to 2016 Super Duty
02-15-2013 05:31 PM
Quick Reply: Places to look for cause of low MPGs
