rocker arm assembly rebuild ..help!
Old 07-16-2011, 07:48 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
so i tore down my tbird 390 rocker assemblies , wow were they gooped up , i found one surprise a broken spacer spring . i founda guy on ebay selling new ones so i ordered one.
here's where i need help i removed the end plugs on the shafts for cleaning , used the sheet metal screw and thick washer method . then pushed the other side out with a long 3/8 rod . so i need to find 2 end plugs anyone know where to get these ?
here's some pics
before
after
Old 07-16-2011, 10:39 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
I see a missing rocker arm in the "after" pic.....
Old 07-17-2011, 08:34 AM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
Dorman #P7C.
NAPA part # CEP 2192098
Original Ford # EAA-6572-A
Not sure the NAPA # is still good but maybe?? You'd have to check and the Dorman # should be correct. I'm also not sure if the Ford and aftermaket Sealed Power shafts use the same plugs. For such a simple plug it can be a real pia to find the right ones. Let us know how you make out and what you use. Good info for the future.
tater_51's Avatar
tater_51
tater_51 is offline
I found mine at the local hardware, but any good parts store, NAPA, etc. should have them.
Old 07-17-2011, 09:00 AM
MIKES 68 F100
THANKS, i left the rocker arm off to remind me about broken spring , didn't think i was going to find them . i'll be hitting lowes today
Old 07-22-2011, 03:34 PM
MIKES 68 F100
as for the plugs i found copper end caps that are a hair big, going to size them down to fit.
all auto /hardware stores having nothing around here
MIKES 68 F100
248
05-22-2016 06:19 PM
MIKES 68 F100
77
12-30-2015 01:19 PM
MIKES 68 F100
30
11-18-2015 07:40 AM
MIKES 68 F100
23
11-11-2015 06:56 AM
MIKES 68 F100
04-25-2011 08:18 PM
Quick Reply: rocker arm assembly rebuild ..help!
