rocker arm assembly rebuild ..help! - Ford Truck Enthusiasts Forums
Old 07-16-2011, 08:48 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is online now
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
so i tore down my tbird 390 rocker assemblies , wow were they gooped up , i found one surprise a broken spacer spring . i founda guy on ebay selling new ones so i ordered one.
here's where i need help i removed the end plugs on the shafts for cleaning , used the sheet metal screw and thick washer method . then pushed the other side out with a long 3/8 rod . so i need to find 2 end plugs anyone know where to get these ?
here's some pics
before
after
Old 07-16-2011, 11:39 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
I see a missing rocker arm in the "after" pic.....
Old 07-17-2011, 09:34 AM
FFR428's Avatar
FFR428 FFR428 is offline
Needsmorecoffee.
FFR428 has a good reputation on FTE.FFR428 has a good reputation on FTE.
Dorman #P7C.
NAPA part # CEP 2192098
Original Ford # EAA-6572-A
Not sure the NAPA # is still good but maybe?? You'd have to check and the Dorman # should be correct. I'm also not sure if the Ford and aftermaket Sealed Power shafts use the same plugs. For such a simple plug it can be a real pia to find the right ones. Let us know how you make out and what you use. Good info for the future.
tater_51 tater_51 is offline
tater_51 is gaining momentum as a positive member of FTE.
I found mine at the local hardware, but any good parts store, NAPA, etc. should have them.
Old 07-17-2011, 10:00 AM
THANKS, i left the rocker arm off to remind me about broken spring , didn't think i was going to find them . i'll be hitting lowes today
Old 07-22-2011, 04:34 PM
as for the plugs i found copper end caps that are a hair big, going to size them down to fit.
all auto /hardware stores having nothing around here
9" and front Discs rebuild MIKES 68 F100 1967 - 1972 F-100 & Larger F-Series Trucks 248 05-22-2016 07:19 PM
POLISHED 2 of my wheels MIKES 68 F100 1967 - 1972 F-100 & Larger F-Series Trucks 10 03-25-2013 03:07 PM
My stereo & speaker install MIKES 68 F100 1967 - 1972 F-100 & Larger F-Series Trucks 19 09-03-2012 10:17 AM
orig 360 tear down MIKES 68 F100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 10-24-2011 10:04 AM
saddle blanket seat cover MIKES 68 F100 1967 - 1972 F-100 & Larger F-Series Trucks 2 05-07-2011 07:20 PM
Tags
1972, 2004, 292, 360, 69, arm, assembly, broken, engine, explorer, ford, international, rebuild, remove, rocker, springs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
