Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 07-16-2011, 07:25 PM
05blueEx 05blueEx is offline
Garage is empty, add now
05blueEx is starting off with a positive reputation.
rear AC on 2005 excursion is not blowing cold air
A/C wasnt working took it to a shop they put in new compressor front worked great, but no rear air. So they put in a rear expansion valve. Still not cold in the rear! I checked both rear blend door actuators and they seem to work properly. Im at a loss what else could it be? Could it be the front blend door behind the glove box causing cold air to not reach the rear? I'm stuck and have no clue what else to look at or research..
  #2 (permalink)
Old 07-16-2011, 08:41 PM
simplyrob's Avatar
simplyrob simplyrob is offline
simplyrob is starting off with a positive reputation.
Does it blow hot heater air to the rear? Mine did but not cold. Therefore it was the rear expansion valve. Just got it fixed today.
  #3 (permalink)
Old 07-16-2011, 09:56 PM
Sader's Avatar
Sader Sader is offline
Sader is gaining momentum as a positive member of FTE.
If the shop installed a TXV in the rear and the A/C does not work properly, take it back to them. Maybe they installed it incorrectly?
Cheers
__________________
2005 F250 PSD, C/C, 4x4, T/S, Lariat : 2000 Excursion PSD, 4x4, Limited, Large Edition, 200k club : 1996 Explorer Sport 4.0L OHV, 4x4, XLT
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
  #4 (permalink)
Old 07-18-2011, 04:27 PM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
Quote:
The air handling systems in front and back are separate so one will not effect the other. They share a common coolant and compressor system. The most common issue for the rear is the TXV. Seems to me the shop should not have given it back to you if they did not confirm it was working first. I'd take it back.
The next, much less likely issue is there is major blockage in the rear evaporator. NOT LIKELY AT ALL.
I think they got a bad TXV.
__________________
2004 Excursion XLT, 4X4, V10, 3.73 - pulling a 30' Hornet Travel Trailer 154,000 mi - 09/2010 - new to me 163,500 mi - 02/2012 174,000 mi - 4/2013
  #5 (permalink)
Old 07-18-2011, 06:38 PM
Ok the blend door actuator behind the glove box was bad, so now my question is since that door was not in the correct position would that cause the rear to not get cold?
  #6 (permalink)
Old 07-19-2011, 12:48 AM
simplyrob's Avatar
I'm stumped. Maybe the new TXV is bad. Did they use OEM parts?
  #7 (permalink)
Old 07-19-2011, 03:41 AM
corpuspits corpuspits is offline
corpuspits is starting off with a positive reputation.
did they change the orfice tube.
Tags
2005, 2006, ac, air, blowing, cold, conditioner, conditioning, excursion, f250, ford, rear, stuck, superduty, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
