Installing Throttle Position Sensor - Ford Truck Enthusiasts Forums
Old 11-17-2014, 07:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Old 07-16-2011, 07:18 PM
iwals's Avatar
iwals iwals is offline
iwals is starting off with a positive reputation.
I'm needing to put a new TPS on my 1986 F150 302 EFI. My Hayne's book says to adjust it until the voltage reads 1.0 V. However, I don't see how this can be mounted except exactly one way. It has two holes for screws and when you put those through, even loosely, there is no give to turn. The part that is turned by the throttle is inside the case that mounts with the screws.
The two yellow arrows point to what engages with the tangs that extend out of the throttle body.
The book says there is no adjustment needed on the 6 cylinder. Maybe they made a mistake and the 302 V8 doesn't have a means of adjusting either. I would appreciate anyone's help with this.
Old 07-16-2011, 08:04 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
There is a little bit of movment, not much. I have had to break out the rat tail file in the past and open the holes up on aftermarket units. As long as no one has dicked with the base idle screw, a motorcraft unit should be about dead on.
Old 07-17-2011, 01:57 PM
iwals's Avatar
Thanks. I reemed the holes out a little and was able to adjust it to 1.04 volts. The truck seems to run and idle fine now, a lot better than when I limped home with it.
Old 07-17-2011, 05:52 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
As Archion said, the only time a TPS should need adjusted is when the base idle screw is adjusted. This is why factory replacement TPS units do not have enlarged holes that allow you to adjust the TPS. I sure hope the TPS screws on the older trucks are easier to remove than the newer Fords. For some reason Ford decided to locktite the screws on the newer vehicles, and the only way to remove them is with vise grips when the screw is hot, or cut the heads off and then remove the screws with vise grips.
Old 07-17-2011, 08:24 PM
Archion's Avatar
1.04 is still way too high. Your idle screw has been dicked with. Needs to be .9 to 1.0 Max. You need to look up setting the base idle on your motor.
Old 07-18-2011, 11:15 AM
iwals's Avatar
Thanks for the posts. As far as the TPS, I had to remove the throttle body to get to it, and yes I had to use my itty-bitty vise grips to turn the screws. I'll see how it goes. I don't know how accurate my meter is; the battery connector broke on my Craftsman meter and I could only get a cheap China-made one at Harbor Freight. I had read somewhere that 0.1 volts was the accepted tolerance on the base setting of these TPSs, so I thought the 0.04 volt overage would be OK.
Old 07-18-2011, 11:54 AM
Archion's Avatar
.01 was enough to actuate and flutter the solenoid bank for the egr on my truck. As wella s throwing the mixture off. The ecm thought it os off-idle so time to open the EGR... didnt make for a good running truck...
The procedure I came across a while back was to disconnect the IAC and set the base idle @550-650 rpm that way, and then revisit the TPS voltage. Should put you in the neighborhood.
adjusting tps gammatino 1987 - 1996 F150 & Larger F-Series Trucks 2 09-01-2014 07:10 PM
TPS adjustment hotrod351 1987 - 1996 F150 & Larger F-Series Trucks 19 01-14-2013 09:45 PM
TPS Install and adjust on AOD jmart08 1987 - 1996 F150 & Larger F-Series Trucks 6 02-09-2011 08:10 AM
1986 F150 Runs Rough, sometimes iwals 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-22-2010 05:44 PM
Is it necessary to adjust TPS? gmk035 1987 - 1996 F150 & Larger F-Series Trucks 3 03-14-2010 07:09 PM
Tags
150, 1986, 2003, 2005, 46, adjusting, econoline, ford, install, installing, position, sensor, throttle, tps, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
