thermostat stuck open? - Ford Truck Enthusiasts Forums
Old 07-16-2011, 05:22 PM
ricg ricg is offline
ricg is starting off with a positive reputation.
i was pulling a trailer with some topsoil today and notice when i take off my Engine temp drops to C and even when im drinving down the highway it stays below normal.. does that sound like a stuck open stat?? i live in Texas so the temp aroung here is about 90
Old 07-16-2011, 05:27 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Maybe a bad temperature sensor also.
Old 07-16-2011, 06:11 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Unplug the temp. sensor and see what the temp. gauge says. Then ground the lead, the gauge should go the other way full swing. If so, replace the t-stat. That's the way we used to test them anyway.
Old 07-16-2011, 07:54 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
What gauges do you have? Or are you using the in dash idiot gauge to see the coolant temp?
Gauge, or sending unit? 76F100guy 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-26-2015 09:40 PM
Coolant Temp and Oil Temp Delta Towzilla 6.0L Power Stroke Diesel 16 05-26-2014 08:25 AM
Iac stuck open. brandonnichols 1987 - 1996 F150 & Larger F-Series Trucks 2 03-26-2014 10:21 AM
Need Help with 2002 Expo Firepuppy Expedition & Navigator 3 03-17-2014 07:34 PM
Cooling issue after radiator replacement linusr Ranchero & 1961 - 1967 Econoline 10 09-14-2013 10:42 AM
Tags
2008, 352, 65, 97, closed, delete, egr, explorer, f100, ford, open, ranger, size, stuck, thermostat, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
