Miller 211 and 0.025" wire?
Hello folks. I have a Miller 211 MIG welder. I've bought some "Easygrind" wire in a 0.025" size. I just discovered that the welder only came with 0.030" and 0.035" tips. No problem, I go online to see if I can buy one in the right size only to find out they only make a 0.023" tip for the 211, not a 0.025" tip.
Are the two size close enough that it does not matter? Can 0.025" wire work with the 0.023" tip?
Any help appreciated.
Gustave
Gustave
on
1 Post
Gustave
Gustave
Gustave
on
1 Post
You could try Hobart? Miller owns them now and alot of stuff interchanges between them sometimes? But I'm telling you I dont think you'll have any problems running the .030tip with your .025 wire. I think it will be fine. You also need to make sure with all welders to clean your feed rollers from time to time but especially if this one dont have the double gear drive? I'm not familiar with this model Miller? I only use Miller in my shop but mine is an older model. Mine is a Millermatic250.
Hope this helps man
Hope this helps man
I weld for a living and we always use a tip that is a little bigger than the wire, this helps to keep the wire from dragging and burning back in the tip. For .035" aluminum, steel and bronze wire we use a .044" tip and on 3/64th's aluminum wire we use a .063" tip which is about .016" bigger than the wire.
on
1 Post
Yep, I knew I was right about that or thought I was anyway. I tried using the same size tip on SS wire and it bound up something terrible. It would be better to run a little bit bigger tip on there and keep it from "bird'snesting" in the feed drive. That's not so much of a problem on my machine but on the single wheel drive machines (without the other gear) they are bad about bird's nesting the wire cause of burnback at the tip which is really aggrivating I hate rethreading wire through the gun .
Dr G
08-23-2016 08:41 PM
BigBlocker0248
01-17-2016 03:20 PM
mrstubb
06-13-2010 08:59 AM
