oil pressure loss
oil pressure loss
I had 35psi at idle this morning and pretty much sense I have had the truck. Decided to take the truck into work and 15 miles in I stopped and the at idle oil pressure was 0! When I got back onto the freeway the oil pressure went up 35 psi it used to be at 60. I just put in new lifters and did an oil change. 10w 40 oil. What would cause the rapid oil pressure loss. It also still have a ticking when come to a stop which sounds from the top end (why I changed the lifters) it only does it between 1500rpm and 1000. I really hate this engine. Nothing but problems from it.
That ticking is probably your lifters from lack of oil. One of 3 things I can think of.
1. You messed something up doing the oil change.
2. Mains are going out.
3. Oil pump is going out.
You'd better figure it out while you still have an engine. FE engines are quite stout and bullet proof if done properly. Nothing wrong with 10W40 oil in her. That's what I run in my 428CJ with no problems.
Yes you can pull the pan with it in the truck. Did this start after the oil change??? It could be a collapsed oil filter with a bad bypass valve. What filter are you using 1515 Wix or FL1a Motorcraft I hope? The oil pumps almost never go bad , but what can go bad is the gasket between the oil pump and the block and then oil just bypass right back into the pan. Or it can be a blocked oil filter screen, how clean is the engine inside???
Fram = Orange can of Death.
Many have heard the rumors of a Fram filter that disintegrated. I've seen it 1st hand...... It looked like someone stuffed a roll of toilet paper into the oil filler, and it went everywhere inside the oil passages......
Was about 20 years ago, and I haven't bought a Fram filter since.
The other possibility is your guage is malfunctioning. Is this the factory guage? My temp guage would get real far to the right, to the point of scaring me, oil would get real low on warmup. I hooked up a set of mechanical guages and temp never gets warmer than 190 deg and oil is 50 psi cold, 30 warm.
