Edge Evolution - change gauges on screen
I have an evolution, not sure how old or what version. It currently shows boost, eng temp, trans temp, and EGT. I want to view EOT, ECT, EGT, and Trans Temp. Anyone know how to change it? Also, I'm getting an EGT error code, and the reading is showing in the 125-175 range. Anyone know how to fix this? Thanks.
Look on the back and/or side of the unit and it will have a label with a part and version number's. That'd help. It'd also help to know what year, etc truck it is in.
As far as the code, that's not a diesel engine code, I don't know what it is. You might need to go to Edge Products| The Leaders in Performance Electronics and contact their tech support. If the problem is the EGT probe, you can buy a replacement.
If you go to the Edge website you can down load the full manual for your unit. Then on the same site you can plug in your unit to a USB and download updated current software that will bring your current. The manual will walk you threw it and they have great help on the phone if you get stuck.
TheBludgeon
02-06-2013 07:55 AM
jakermc
12-07-2007 10:42 AM
