4r100 problems
4r100 problems
Hi,
Fairly new here and I'm looking for advice. I've got a 2000 f350 v10. I've been experiencing very hard upshifts going into all gears lately after the truck gets good and warmed up, mainly if i've been sitting in traffic or towing. A few times it has seemed to go into neutral while driving along. This seems to happen if i shortly back off the gas then get back on it. Just had it at the ford dealer and there are codes for the output shaft speed sensor and cam position sensor. Prior to taking the truck to the dealer i replaced the cam position sensor but that code keeps coming back. They are telling me that the hard shifts could be explained by the faulty sensors but the "going into neutral" symptom will require a new tranny or re-build in order to be solved. Is what they are telling me accurate or could the faulty sensors be the cause of all my symptoms. I also recently change tranny fluid and filter. The old fluid looked clean and after a few hundred miles the new fluid is still clean.
Any feedback is much appreciated.
Thanks
Frank
Thanks
Frank
Going to neutral might be those sensors, but it is more likely the TRS (Transmission Range Sensor) on the driver's side of the trans. The other two sensors are probably causing the hard shifts.
It actually is even more likely that it is the wiring to the sensors, not the sensors themselves.
ridinginstyle
45
09-21-2015 03:09 AM
charles5000
01-28-2014 07:31 AM
tyrus
08-30-2001 07:09 PM
