Front Axle U-Joint Replacement
  #31
Old 07-16-2011, 02:55 PM
rocknut's Avatar
rocknut
rocknut is offline
Funny how we talked about u-joints I had to remove a u-joint from a drive shaft in my off road buggy to repair a drive shaft I twisted. I had to cut off the twisted tube and weld on a new tube. The tube had twisted off till it snapped in two. To much HP dropping off a ledge on the rear end. Snap crackle and pop was the sound. Oh the joy of having fun. Good thing I can do these repairs I'd be broke.
  #32
Old 07-16-2011, 08:01 PM
mblanken881's Avatar
mblanken881
mblanken881 is offline
It was the u-joint. One side of it was all dried out and rusty. Won't neglect to grease them anymore. Ended only replacing the u-joint. Didn't feel like replacing the ball joints at this time and they seemed fine. Besides, it doesn't take long to get to them.
My 0.02: I don't think a guy needs to replace the seals everytime. I was able to get everything apart and the seals were all reusable. I used the new ones since I had them but the old ones definitely could have been reused. This is why I didn't replace the ball joints right now.
Thanks for all your help guys!!
  #33
Old 07-16-2011, 10:42 PM
JESTERxHEAD's Avatar
JESTERxHEAD
JESTERxHEAD is offline
glad you got your issue taken care of! yea its just a good idea to check the ball joints and yea I wouldnt replace them unless they needed it anyways. also its just good to get the seals just as a precaution if the tear....
  #34
Old 03-10-2015, 08:05 AM
queen of spades's Avatar
queen of spades
queen of spades is offline
Arrow
So could someone help get a part # list together for U-joint replacement?
I have the actual U joint:
Spicer SPL55-3X
Amazon.com: Spicer SPL55-3X U-Joint Kit: Automotive Amazon.com: Spicer SPL55-3X U-Joint Kit: Automotive
Need to know what seals to order. Looked like there were two per side.
A video showed a guy using an "updated" axle seal with a metal end. Hoping to find that part #.
Some related helpful posts:
https://www.ford-trucks.com/forums/1...ust-cover.html
https://www.ford-trucks.com/forums/3...ll-joints.html
https://www.ford-trucks.com/forums/7...nt-axle-2.html
  #35
Old 03-10-2015, 08:36 AM
Super Duty Service's Avatar
Super Duty Service
Super Duty Service is offline
Former Vendor
The spicer 3x's are the non greasable. I only install 4x's,,, Those are the greasable ones. We normally have them in stock. NOBODY in KC has 4x's in stock,,, except us!!! Lol
  #36
Old 03-10-2015, 09:13 AM
queen of spades
Saved by the bell. Thanks. Hadn't ordered yet. Found that the local jobber has Moog u joints in stock, and those are also greasable. I am also replacing the hub assemblies (Moog).
Still trying to hunt down part numbers for seals I will need.
  #37
Old 03-10-2015, 01:54 PM
Super Duty Service
Former Vendor
These are the ones you want
I took a pic so you would know they do exist,,, contrary to what EVERY parts store might tell you. If you want a set,, you can call the shop n we can get a set out to you. However,, we are not an online store,, we are a shop with parts in stock,,, I gotta eat so you can get better prices elsewhere. Iirc they're gonna be about $75 each. I don't even try and compete with online sales. Lots of places sell parts and make pennys.
  #38
Old 03-10-2015, 01:58 PM
queen of spades
Got the bearing part numbers, the seals are what I keep asking about.
I didn't have time to read the entire ball joint thread, maybe someone listed them in the 30+ pages of replies. Or maybe they are in the first post and I overlooked them. I had to go to work to earn money to pay for this repair. Hope someone has easier access to those seal part numbers.
  #39
Old 03-11-2015, 07:14 AM
Super Duty Service
Former Vendor
Ok,, I can get the seal numbers in a lil bit. But I would use the spicer u-joints over the moog. But moog is the ball joints I would use.
I've only used Ford hub assemblies,, if possible,,, Can you not forget this thread and check in with updates on how the moog hubs hold up??
  #40
Old 03-11-2015, 08:22 AM
queen of spades
You betcha.
Still looking for seal part numbers if anyone has them can you please reply? Many thanks.
  #41
Old 03-11-2015, 08:33 AM
queen of spades
Nevermind on the seals, I found what I need.
Ill updated this thread as I work through the repair & beyond.
  #42
Old 03-24-2015, 08:19 PM
queen of spades
Having trouble getting the driver's side u-joint clips removed. They are rustwelded to the yoke & bearing cups.
What can be done to get these things to pop off?
  #43
Old 03-24-2015, 09:48 PM
87crewdually's Avatar
87crewdually
87crewdually is offline
Hit the circlip with a cold chisel straight down on the flat portion. It should pop loose.
I normally just cut the cross out with a cutting torch then tap the caps inward easily with a ball peen hammer.
  #44
Old 03-24-2015, 09:53 PM
queen of spades
Update, kept working at it with kroil and tapping with a hammer. Got the 4 clips out then worked on the cups. Ready to install the new Spicer now.
Budman1962
1999 to 2016 Super Duty
08-30-2015 09:50 AM
Snuggyworm
06-04-2014 02:17 AM
5.4L to Freedom
01-17-2011 08:13 AM
iron1951
08-27-2009 01:24 PM
MikeFlorida
05-13-2007 06:52 PM
Quick Reply: Front Axle U-Joint Replacement
