Cab Interchange
Old 07-14-2011, 08:34 PM
Truck problems2's Avatar
Truck problems2
Truck problems2 is offline
Cab Interchange
Can you put a 78 cab on a 74 narrow frame truck?
Old 07-14-2011, 08:50 PM
Tsoptich's Avatar
Tsoptich
Tsoptich is offline
I am putting a 78 f250 2wd cab and body on a 74 f100 4x4 frame. All the holes match up.
Old 07-14-2011, 10:35 PM
highboy1975's Avatar
highboy1975
highboy1975 is offline
what is a narrow frame truck? whats the model? f350?
Old 07-14-2011, 10:43 PM
650's Avatar
650
650 is offline
I assume you mean highboy and the answer is yes. The front mounts will be the same. The back 2 though will need to be re-drilled though since the highboys mounts are on the outside instead of on the inside. At least this is how it worked out for my truck when we did the swap. My swap was a 78 F.150 2wd cab onto a 1976 highboy.
Old 07-15-2011, 12:01 AM
RunninD's Avatar
RunninD
RunninD is offline
Unless you are putting the cab on a hiboy the frame mounts are identical. The only variation I have found in the 73-79 standard cabs in the Hiboy. In that style (F250 4X4's) the rear mounts are wider. otherwise the cabs all mount to the frame without any issues
berlincam86
74
03-17-2019 09:26 AM
berlincam86
'80-'86 FAQs (Frequently Asked Questions)
59
09-30-2016 12:20 PM
speakerfritz
1999 to 2016 Super Duty
05-08-2016 04:45 PM
Eaglescout94
07-09-2015 08:51 AM
johnfin1
11-02-2014 11:39 AM
Quick Reply: Cab Interchange
