Cab Interchange - Ford Truck Enthusiasts Forums
Cab Interchange
Old 07-14-2011, 08:34 PM
Truck problems2 Truck problems2 is offline
Truck problems2 is starting off with a positive reputation.
Cab Interchange
Can you put a 78 cab on a 74 narrow frame truck?
Old 07-14-2011, 08:50 PM
Tsoptich's Avatar
Tsoptich Tsoptich is offline
Tsoptich is starting off with a positive reputation.
I am putting a 78 f250 2wd cab and body on a 74 f100 4x4 frame. All the holes match up.
Old 07-14-2011, 10:35 PM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
what is a narrow frame truck? whats the model? f350?
Old 07-14-2011, 10:43 PM
650's Avatar
650 650 is offline
650 is starting off with a positive reputation.
I assume you mean highboy and the answer is yes. The front mounts will be the same. The back 2 though will need to be re-drilled though since the highboys mounts are on the outside instead of on the inside. At least this is how it worked out for my truck when we did the swap. My swap was a 78 F.150 2wd cab onto a 1976 highboy.
Old 07-15-2011, 12:01 AM
RunninD's Avatar
RunninD RunninD is offline
RunninD is gaining momentum as a positive member of FTE.
Unless you are putting the cab on a hiboy the frame mounts are identical. The only variation I have found in the 73-79 standard cabs in the Hiboy. In that style (F250 4X4's) the rear mounts are wider. otherwise the cabs all mount to the frame without any issues
FAQ - truck cab interchange? berlincam86 '80-'86 FAQs (Frequently Asked Questions) 59 09-30-2016 12:20 PM
approx weight of 2010 f-450 Crew Cab, cab only speakerfritz 1999 to 2016 Super Duty 6 05-08-2016 04:45 PM
truck cab interchange? berlincam86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 61 05-05-2016 12:49 PM
Cab Repair Eaglescout94 1999 - 2003 7.3L Power Stroke Diesel 8 07-09-2015 08:51 AM
Front cab mount 49' johnfin1 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-02-2014 11:39 AM
Tags
1976, body, cab, ford, highboy, interchangeability, standard
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
