2004 F-150 Died, won't start - Ford Truck Enthusiasts Forums
Old 07-14-2011, 08:43 PM
TonyJestis's Avatar
TonyJestis TonyJestis is offline
TonyJestis is starting off with a positive reputation.
My friend has a 2004 F-150 with 5.4L V-8. He was leaving work and the negine died. Engine would crank, but would not re-start. No lights, no codes thrown, just wouldn't start. He pushed it back into the lot and let it set. He replaced a fuel filter (didn't prime it by turning key on and off) and then tried to restart,. Wouldn't start. Assumed fuel pump. We removed old pump from tank and turned key on and off. pump runs fine. Now reinstalling pump and tank. i was not there when pump removed, so i don't know how it came apart, but the pump is hitting the bottom of the tank!
The next step will probably be to remove the bed from the truck, reinstall the tank, and work from the top to put the pump back in.
Anyone have a similar problem or have any suggestions?
Zero fuel pressure... GotThreeOfThem 1987 - 1996 F150 & Larger F-Series Trucks 9 07-10-2013 06:58 AM
92 f150 fuel pump won't shut off and won't start! buckeyebrad 1987 - 1996 F150 & Larger F-Series Trucks 13 01-20-2010 12:22 PM
Fuel issues, I -think- I have the culprit. bmonnig 1987 - 1996 F150 & Larger F-Series Trucks 8 01-11-2007 09:48 PM
I think my truck has gremlins!!! d_stange 1987 - 1996 F150 & Larger F-Series Trucks 36 06-21-2006 07:41 AM
Another stalling 302 EFI 72F250390 Fuel Injection, Carburetion & Fuel System 16 07-15-2005 06:20 AM
Tags
150, 2004, 20042008, 2005, 2006, 2008, crank, die, died, f150, ford, fotd, start, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
