Dislike - Open doors, parking lights come on
One of the *features* I dislike is that when I open the exterior doors, the parking lights come on. Day or night.
I'd like to be able to open the door without drawing attention that I am at my vehicle at night. (even if it is not running.)
Is there a way to disable this? I couldn't find anything in the manual.
I also REALLY miss the dome override feature that GM has.
Sometimes, I want to leave the door open, but not have any dome lights on at night.
I took off the door panel and found the wire that "Trips" when the door is opened. Basically it is grounded when closed & not grounded when open. I cut it & ran it to a rocker switch on the drivers side door panel - grounded the switch so that when activated it would keep the wire grounded.
It did the trick - No interior or exterior lights, no dings , etc. But, then it also would show door ajar all the time ... I finally disconnected - I'm on the right track, but I need to dig back into it and get it to work...
I was wondering if it was something we can program (haven't pulled out my book yet). I don't mind it now, but I'm going to bolt up a set of running boards off my last tuck that have both amber running lights and the clear puddle lights. Defeats the purpose of the clear lights plus ALOT of lights to be turning on every time I open my door. Does any one know if the trailer light circuit operates the same way? If not I'll just be sure and tap my running boards into the trailer lights.
