1978 - 1996 Big Bronco
Radio light bulb
Old 07-14-2011, 11:44 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
Radio light bulb
Anybody know the model number of the bulb? Mine is burnt out.
Thanks
1993 Bronco Casset player
Old 07-14-2011, 05:24 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Never been that far into the guts of an OEM stereo unit. Wish I could be of some help but I used that same issue as an "excuse" to upgrade audio components.
If you do get inside the unit, I'd be looking at some sort of 12VDC LED retrofit instead of a standard lamp. Its not likely to be easy to get to in the first place so putting something in that you can forget about once its been fixed seems worth the expense.
Old 07-14-2011, 07:44 PM
g_k50's Avatar
g_k50
g_k50 is offline
I replaced the led light in my 1990 AM/FM only radio,
It's not that big a deal, and the bulbs are readily available.
Go for it and get the same model you take out.
mofoco1
10-13-2017 12:29 PM
GORDEN1234
2015 - 2020 F150
03-06-2017 08:13 PM
cullenkyla
2015 - 2020 F150
09-17-2016 05:43 PM
pyro2
13
09-27-2014 12:38 PM
berry1234
22
05-30-2009 06:48 PM
Quick Reply: Radio light bulb
