EGR Delete Question? Put EGR Valve back in hole?
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtNodeId="1530"> <!-- / icon and title --><!-- message -->
Hello fellas.
Truck:
2006 6.0l PSD, River City Diesel EGR Delete, custom SCT tunes (street, tow aggresive with turbo brake, and economy.) Had my CCV rerouted, EGR turned off via the SCT, and a coolant filter since practially new. Truck has 97,000 miles on it. Coolant filter has saved my oil cooler, as verified by my Scan Gauge II.
I just completed my River City Diesel Delete and noticed my boost maxed out at 21 lbs which is lower than before, EGT's are lower too. (goodbye POS passenger side up pipe scoop!!).
I'm OK with this because it runs like a champ!!
I'm ok with lower boost numbers & EGT's myself as it should help reliability. No studs.
Mileage not affected.
No exhaust leaks! Was not fun working around my Magnaflow 4" downpipe.
EGR cooler didn't fail but she looked like it got hot from the discoloration where the EGR Cooler/Uppipe met. Had minor puking when towing 11,000 lbs, and pushed hard.
Anyway here is my question:
I put the River City EGR valve delete "plate" where the EGR Valve once was.
I promptly got the check engine light with a P0403 & p0405. Called Innovative Diesel and they said to just plug the EGR valve back in and leave it on top of the engine. Check engine light off.
The EGR Valve looks like **** laying there on top of the engine plugged in.
Can I just put the EGR valve back in the hole with it plugged in?
Or will I leak boost? I can't tell from the 6 liter bible pictures.
Thanks in advance.
<!-- / message -->
Hello fellas.
Truck:
Thanks in advance.
<!-- / message -->
<!-- controls -->
genscripter
19
05-10-2015 03:57 PM
