New To Ford: Inline 6 to 5.0 Swap
#31
All good points Paul... I think we can safely assume that T5 would be a PITA compaired to just using the M50D.
Hondasux,
You might look into getting a 351w from a truck (or get donor truck) and use the accessory pully's from the 351w on the 302. Then you can rebuild and repower the 351w over time and then when the 302 just isn't cutting it you can put the 351w in and have MORE POWER! Just a thought b/c I know you can get full 351w around here for a couple hundred bucks from an old truck and you could get the radiator at the same time.
Hondasux,
stoverjandro
61
08-11-2017 03:21 PM
