1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-25-2014, 02:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
Print Wikipost
front drive shaft spinning while in 2wheel drive
Old 07-14-2011, 09:39 AM
stlrisk's Avatar
stlrisk
stlrisk is offline
I have a 1999 Ford F250 super duty 4wheel drive, lifted(really a leveling kit but had to lift rear to compensate), 5.4l. Im having a problem with my front shaft turning while in 2 wheel drive. Hubs aren't locked and its in 2 wheel not 4. I've taken hubs off and the bearing spins free soo I know its in auto. Why is the drive shaft still turning???????
Old 07-14-2011, 11:44 AM
thomabb's Avatar
thomabb
thomabb is offline
With the truck in 2wd and the hubs in auto;
1) Try to turn the U-joint behind each front wheel. If one will not turn, you have either a bad U-joint or a hub that is not disengaging.
2) Try to spin the front driveshaft by hand. If it feels locked, there is something hokey in your transfer case.
Having said all that, it is not unusual for the front driveshaft to move when in 2wd. It will drift.
Old 07-14-2011, 11:55 AM
stlrisk's Avatar
stlrisk
stlrisk is offline
I forgot to add, yesterday i was toying w it and it did not turn while pulling out of driveway up street and back down to my driveway. But this morning it moved after I reached 40+mph. I noticed it had moved when I arrived at the gas station.
Old 07-14-2011, 12:20 PM
bpounds's Avatar
bpounds
bpounds is online now
If you are saying your front shaft has turned a little bit, then that is normal. There is enough friction in the hub bearings to make it turn slightly. If you have confirmed that your hubs are free spinning, then you have nothing to worry about.
Old 07-03-2013, 07:12 PM
shirkey42's Avatar
shirkey42
shirkey42 is offline
I have a 2000 f250 super duty. Apparently four wheel drive is engaged but hubs and selector switch show its in two wheel drive . Caused front drive shaft to break at rear u joints on front shaft st transfer case. Drive shaft is removed but front axle is still engaged in four wheel drive. Anyone have any suggestions on what to do?
Old 07-03-2013, 10:05 PM
bpounds's Avatar
bpounds
If your driveshaft broke, that means the transfer case is locked in 4WD. You might also have locking hub problems, but hubs being locked in won't break a driveline. Since it appears that both hubs and TC are locked, maybe you should start with checking the electrical system.
drewduncan15
19
04-10-2019 08:37 PM
1993 ford
05-26-2017 01:52 AM
thejermsr
13
02-18-2017 11:02 AM
tjgalinski
08-28-2015 08:42 AM
golfpro1592
11-17-2010 08:33 PM
Quick Reply: front drive shaft spinning while in 2wheel drive
