biggest aftermarket tires on stock 20" rims - Ford Truck Enthusiasts Forums
Old 07-13-2011, 11:49 PM
blue oval fan's Avatar
blue oval fan blue oval fan is offline
blue oval fan is gaining momentum as a positive member of FTE.
i came across the nitto trail grappler mt tire and they dont make a size thats very close to the stock tires that came on my 20" rims. i really want these tires! i am curious as to how big you guys are goin on tire sizes before they start rubbing on any other parts of the truck. the sizes they have are: 35x12.50r20 37x12.50r20 lt295/55r20 305/55r20
any info would be great
Old 07-14-2011, 07:27 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
Biggest I would go is what Epicowlick has, 315/60/20
He states that they just barely rub up front at full steering lock and he has a F350 SRW with a 2" level kit, so his tire fit is very close to a stock truck config.
Old 07-14-2011, 08:29 AM
alright thanks!
Old 07-14-2011, 07:49 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Why Not the 295/60R20 which is 34.45" tall . Those will work just fine.
Or the next size up 295/65R20 which is 35.47" tall. You will need to check with overs to see if 35"+ tires need a lift with that width.
Old 07-14-2011, 09:07 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is offline
EpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant future
That's right. My tires just rub the control arms at full lock left or right. Heres what that lookslike:
Old 07-15-2011, 02:27 AM
sedwardson's Avatar
sedwardson sedwardson is offline
sedwardson is starting off with a positive reputation.
I have 37/13.50/20 Toyo MT's on stock rims with a 6'' lift and they rub at full lock in the same place as well.
Old 07-15-2011, 08:43 AM
appreciate the help here guys. id hate to buy a set and come to find out that they wont work. i will be going with the 295/60r20's after help here and another friend. thanks!
Old 07-17-2011, 10:15 PM
kereams kereams is offline
kereams is starting off with a positive reputation.
Through a huge long comedy of errors I have had three sets of aftermarket tires on my truck in the 8000 miles I have owned it. LoL All of them on the stock 20" rims.
Toyo MT 35x12.5x20, rubbed a little on the control arms. Got rid of these at no cost to me due to them putting on tires that could not handle my camper. Floatation tires in an E are only rated to 3195 per tire. Les Schwaab ate that one.
Nitto Trail Grappler, 295/60R20. These looked awesome and were quieter than the Toyo. The issue here is I had one that was out of round so it pulled to the left. On top of that after two trips with the camper the wide lug spacing showed that it could not deal with the weight of a camper and the torque of the diesel. The lugs showed signs of ripping at the base. Back they went at Nitto's expense.
BFG A/T LT285/65R20 (34.7" tall). These do not rub as they are narrower. Best ride, very quiet and considerably more stable with the camper on. Hopefully this is the last set for a while.
Old 07-17-2011, 11:09 PM
The 285/65 will have less pinch on the stock 8" wide rims, So they should wear better than the wider tires you tried first
Old 10-20-2013, 01:20 PM
Hico Hico is offline
Hico is starting off with a positive reputation.
285/65 or 295/65 20s?
Old 10-20-2013, 06:33 PM
UGA33's Avatar
UGA33 UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
The 295/65/20 Trail Grapplers are rated for 4k lbs. I have towed heavy with that tire a lot with no issues. I would love some BFGs on my factory 20's, but they are so expensive for bigger wheels.
Old 10-21-2013, 10:51 AM
Powelligator's Avatar
Powelligator Powelligator is offline
Powelligator is starting off with a positive reputation.
Just out of curiosity, what do you guys do about speedometer recalibration after going to larger tires/wheels? I'm considering going from the OEM 18" rims/tires on mine to a 20" rim with a larger tire, and wondering if there's a way to fix the speedometer/odometer calibration.
Joe
Old 10-21-2013, 12:14 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
The dealer can recalibrate your truck up to the stock 34.1" tire that comes with the 20" wheels. If you want to go beyond that and keep your speedo accurate you need to look at aftermarket solutions - I have a tuner which is capable of changing tire size.
Old 10-21-2013, 01:54 PM
Good info - Thanks!
Joe
Old 10-22-2013, 08:51 AM
Does Michelin make a 295/65/20? or a 295/65/18?
BFG KO2 Revs/mile data Magnus E Excursion - King of SUVs 12 12-01-2016 09:27 AM
What's a good size rim to run on the Excursion? 78Southwind Excursion - King of SUVs 16 11-12-2016 07:52 PM
35x12.50 on factory 18 inch rims w/2.5" leveling kit DieselBeast01 2004 - 2008 F150 17 01-30-2016 07:07 PM
20x9.. Help needed Jamon_23 Brakes, Steering, Suspension, Tires, & Wheels 1 03-18-2015 08:37 AM
Quick Tire Question fordextreme Brakes, Steering, Suspension, Tires, & Wheels 6 05-31-2002 11:57 PM
Tags
2011, aftermarket, biggest, blue, f250, ford, market, rims, s331, saleen, tire, tires, transit, truck, vans, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
