What is best carb for 460? - Ford Truck Enthusiasts Forums
Old 07-13-2011, 08:10 PM
Dawg House Vern Dawg House Vern is offline
Dawg House Vern is starting off with a positive reputation.
Question What is best carb for 460?
Anybody got an idea of the bst carburetor for 1976 F250 camper special with 460 in it jus trying to get it running good as a seconadry vehicle around town no far trips. if have any insight it would greatly appreciated picked this truck up for $400, I drove it home great no problems once home then realized I neede a carburetor.
Old 07-13-2011, 08:16 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust Ziegelsteinfaust is offline
Ziegelsteinfaust is starting off with a positive reputation.
650 vac sec Holley if its completely stock up to maybe a 750 vac sec if you do the bolt-ons.
I think a Edelbrock 650-750 AVS also would be a good choice, but I am not much of an edelbrock guy
Old 07-13-2011, 09:37 PM
AK FORD GUY's Avatar
AK FORD GUY AK FORD GUY is offline
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
If your 76 F250 is like mine than you have a Motorcraft 4350 Spreadbore carb. If you want to swap it over to a standard squarebore carb, you will need the proper adapter. From what I have found, the Trans-Dapt #2199 seems to be the ticket for the adapter.
I think on the carb side of things, you are about to get a bunch of opinions, so get ready. Don't get me wrong, I think all the opinions are great especially when they are backed by actual experience. There are quite a few carbs that will fit the bill, as well as just getting the 4350 rebuilt (if that's what you have).
Old 07-14-2011, 01:32 AM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
I'm running a Edelbrock 1407 750 cfm. But I am also running d3ve heads Edelbrock performer intake, and a comp magnum cam. So far in the two months I've ran the carb I am completely happy with it.
Identifying carburetor '73 f250 w/ 460 73richards250 1973 - 1979 F-100 & Larger F-Series Trucks 16 10-13-2016 02:28 PM
4300 vs 4180 Carburetor JNYarborough 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-10-2014 06:56 PM
What's the best carburetor for a 460. Statzer 1973 - 1979 F-100 & Larger F-Series Trucks 10 05-14-2013 10:24 PM
compatible heads for my 460? Rovernut Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 10-05-2012 07:01 AM
Vacuum diagram for 1978 F150 78OleBlue 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-08-2008 01:14 AM
Tags
4350, 460, carb, carberator, carbuerator, carburetor, for460, ford, mild, motor, motorcraft, sec, stock, truck, vac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
