1978 460- Do I have a blown head gasket or worse?
First let me say my build on my 1978 f350 2x4 is a budget build. The 460 has oil in the coolant , what are the chances it is just a blown gasket. Engine runs fine, when I picked it up 3 weeks ago I drove it about 50 miles over half in stop and go traffic in 100 degree weather and it did not seem to over heat (temp gage not working), I don't have a bunch of money to waste on pulling the block and having it magnafluxed. So, any advice would be great.
Head gasket could push water into the oil, and should also put some gas in the water. Bubbles, gray coolant, rainbow on the coolant.
Not so much would you get oil in the coolant.
AFAIK there is no place where pressurized oil passes through the head gasket. Drain back oil only. So for oil to go into the pressurized cooling system, it would have to be under pressure. That would mean a cracked block.
Cracked block discussion here:
cracked block - 460 Ford Forum
No real resolution here, but just to show you're not alone:
https://www.ford-trucks.com/forums/6...nt-in-oil.html
ilamir
08-27-2012 03:30 PM
mcculloughrp
04-13-2008 01:26 AM
sb1234_99
07-20-2007 12:20 AM
