6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
well....had a coolant leak! I have joined the club..so do you think it was the radiator?
Old 03-20-2016, 11:44 AM
bdiomus's Avatar
bdiomus
bdiomus is offline
Updated dual o-ring hoses
That's the bottom radiator hose, actually hoses...there are two of them. I just replace them on my truck as well. The coolant hoses on this truck typically leak at the connections to the engine, which is why the updated hoses with 2 o-rings have white ends where they connect to the motor. If yours is leaking at the radiator connection (it appears be), and if the motor-half of the hose doesn't have the white end on it, then get both the bottom hoses. In addition to that, I replaced the upper hose as well, since it wasn't the updated version. I would suggest the same...if it hasn't started leaking yet, it will before long.
FWIW...on the half of the lower hose that connects to the radiator, I would almost be tempted to just change out the o-ring and clean the radiator fitting real real good instead of getting an all new hose - but only if I was positive that is where the leak is occurring, and it's not the radiator itself leaking coolant onto the hose or something like that. There isn't an updated dual o-ring version of the lower hose that connects to the radiator and that one doesn't usually leak like the others so a new o-ring might be all that is needed. The downside is if you're wrong you will have to re-drain the fluid again and mess with it again if the new o-ring doesn't do the trick.
CenFlo73PSD
04-18-2017 10:22 AM
2006powerstroke90
04-01-2017 09:54 PM
arizonian
06-19-2016 11:41 AM
KJNDIVER
61
06-02-2016 08:33 AM
Quick Reply: well....had a coolant leak! I have joined the club..so do you think it was the radiator?
