You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 99 convertible and the top not closing correctly. When I close it the windows are on the outside of the top. The windows seam to be leaning out about a half an inch both sides. I am not sure if top caused the lean or if the window are causing the problem. I there a way to adjust the top? The windows? Does anyone know a a shop in Boise that works on the convertible top if this is something I can not do my self?
I posted on a mustang forum but never have had to good of luck getting back any help and I know all of you on this site are quick to help.
Thanks
Keith
__________________
Keith
1999.5 F350 4x4 lariat, CC, LB, DP Tunner F-5, ccv , 6637 air filter, SS HPX, Hutch mod, 5 inch exhaust, 3 gauge A pillar, BTS VB
99 Mustang GT convertible
1990 f 250 almost 1 millon miles
78 jeep cj-5
I'm assuming you have power windows, so here's my input.
Have you pulled the door panels to check if the glass has dislodged from the tracks? Have the tracks loosened up from their mounting points? Has the regulator become worn out? Sometimes the glass is held in by push-pins and other times they are bolted in. These points get worn out and / or loosen up. Bolts can be tightened, the push pins (plastic) need replacing if they're not part of the glass assembly.
We had a similar situation with my wife's Ford Contour. The driver-side window regulator had to be replaced several times before we traded in the Contour.
(Trouble submitting this reply. I hope it didn't double-post.)
__________________
Craig "IDMooseMan" Peters - Slackmaster #27, Big BSer #4
1997 F-350 XLT 4x4 Crew Cab Long Bed E4OD 4.10:1, 1991 Wilderness 24M
USAF SSgt 1983 - 1992, NAHC Life Member, RIP Gideon 3/14/2011 - Good boy, go play
Homedale Rod and Gun Club Membership Committee Chairman, 1/1/2007 - 12/31/2009
To those that have served, Thank You. To those that haven't served, You're Welcome.
