Clunk when taking off from a stop. ??? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-13-2011, 12:16 PM
knightrider955's Avatar
knightrider955 knightrider955 is offline
knightrider955 is starting off with a positive reputation.
Question Clunk when taking off from a stop. ???
My Superduty recently started clunking when I accelerate from a dead stop. The harder I hit the gas,the harder it clunks. I unbolted the driveshaft from the rear end and the yoke slides easily. Tranny mount looks tight. Could it be the front driveshaft? Sometimes when I brake hard and the truck comes to a complete stop it will do it too. Any ideas?
Old 07-13-2011, 12:21 PM
sddesigns's Avatar
sddesigns sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Try this link.....
2004 F250 Slip Yoke Service
Old 07-13-2011, 12:35 PM
My slip yoke slides fine. U joints are tight too.
Old 07-13-2011, 12:42 PM
respolt respolt is offline
respolt is starting off with a positive reputation.
I bought a 2010 F250 that had the same problem. The dealership said it was strange and after trying several fixes, finally deferred to Detriot to diagnose. After six trips back to the dealership, they eventually decided it was "normal" even though they originally agreed it was not. When I mentioned invoking the Lemon Law, they bought the truck back and gave me a sweet deal on a 2011 F350 Dually. The new truck has 18,000 miles on it and has not yet developed the "normal" clunk. Unless your dealer has an extraordinary service department, you will be in for continued clunks.
Old 07-13-2011, 01:20 PM
sddesigns's Avatar
Quote:
It's not the slipping, it's the lack of grease, try greasing it up.
Old 07-13-2011, 01:41 PM
Ok ok I'll grease it. I just figured that if it was sliding easily, it didnt need grease.
Old 07-13-2011, 01:44 PM
For what it's worth, packing it with grease made no difference on my 2010. That was the second trick the dealership tried, right after checking the torque on all the driveline fasteners.
Old 07-13-2011, 01:46 PM
sddesigns's Avatar
in the pictures of the slip yoke it looks like there is grease in there, mine looked like there was too. I did go away after greasing it up surprisingly. I know it will come back eventually, but it's the way it was designed, so the only cure is grease. So far it's been two years but only about 8K miles.
Old 07-13-2011, 01:51 PM
sddesigns's Avatar
Quote:
He also has a 03 with 100k plus and if it just started doing it, more than likely it needs the grease, mine had about 67K when it started to do it.
It's not like he's going to take it back to the dealer for warranty issues like you did!
Old 07-13-2011, 01:57 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
They will slide in and out fine even when low on grease. When engine torque is applied, there is enough friction to keep it from sliding and thus the 'clunk'. Regreasing should do the trick. I bought a tube of special grease from Ford and would have to grease the slip joint every 50k or so. When I ran out I starting using Super White Grease from NAPA and it seems to last a lot longer (and costs less too...).
Make sure you chock your wheels before you remove the drive shaft. Some very smart mechanics have overlooked this step an ended up in the hospital. Safety first.
Old 07-13-2011, 02:01 PM
sddesigns's Avatar
Quote:
Outstanding point.......
Old 07-13-2011, 02:19 PM
My truck is a 03 F-350 with 113,000 miles on it. Probably never been greased. The only grease I have is wheel bearing grease. Will that work? Its water proof for boat trailers.
Old 07-13-2011, 02:24 PM
sddesigns's Avatar
You have a 96 in your profile..lol
It's all I usually use for just about anything that needs grease.
Old 07-13-2011, 02:27 PM
I think it will work fine. It's blue right? The Ford stuff is blue also so at least it's the right color.
Lube up the splines nice and good and then apply a little bit in the receiver as well. Not too much though, you don't want to pack it full because the pieces won't be able to slide back and forth as needed. I usually slide the splined shaft in as far as it will go just to confirm there isn't too much grease and fasten the other end to the pinion yolk.
Old 07-13-2011, 03:03 PM
Ok so I just did it. I slide the yoke off and covered the shaft with grease. But when I slid the yoke back on it pushed most of the grease back off. So I guess we'll see if it works.,
Clunk When Starting or Stopping - 2008 F-250CCSB4x4 scottjima 1999 to 2016 Super Duty 226 08-26-2016 03:37 PM
clunks when starting from dead stop bull119 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 06-29-2015 07:38 PM
Clunk when accelerating from stop kameronth 2009 - 2014 F150 14 07-17-2014 10:51 AM
Clunking when moving from stop EMS-guy 1999 to 2016 Super Duty 16 08-19-2011 09:01 PM
clunk when accelerating from stop 78_f800crewcab4x4 Excursion - King of SUVs 14 11-26-2010 02:32 PM
Tags
05, 2004, 2009, clunk, diesel, f150, f250, f350, ford, rear, stop, superduty, taking, transmission, whenstop
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
