Lift kit for 35" tires on F250 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-13-2011, 12:54 AM
Jayybird Jayybird is offline
Jayybird is starting off with a positive reputation.
Fellas,
I would like some input for a lift on my truck. I am currently all stock. I want to run 35" tires without them rubbing. I am not looking for anything crazy, I would like to be able to run those tires without getting a crazy lift, just want to beef up the look without sacrificing quality of ride. I am not familiar with types of lifts or how they are done. I did call around and a few folks mentioned that a leveling kit would best, to do hat they said they would raise the tuck 2.5" in the font (not sure how) and 1" in the rear oh blocks.
What y'all think? Anyone out there running 35" on a f250 (2003-2007) with a similar setup? Would luv to see some pics
Thanks, would luv to hear any suggestions:
Old 07-13-2011, 07:27 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Quote:
What year truck do you have, because 2005 and later have coil springs in front rather than leaf springs. That makes a difference on how you lift it and what it costs.
You should be able to run 35's with no lift, but a level kit will give you some added room.
Old 07-13-2011, 08:12 AM
My truck is a 2005 FX4 Lariet. It does have coiles in the front, not leaf springs.
What do you tink would be the best way to go? Any thing i should avoid doing?
Old 07-13-2011, 09:49 AM
stumpbuster's Avatar
stumpbuster stumpbuster is offline
stumpbuster is starting off with a positive reputation.
coil spring spacers, 2.5"
kit costs 28 bux..
doin mine this weekend
did exact same thing 2 years ago
simple, easy, effective, done
Old 07-13-2011, 12:36 PM
Jocaren's Avatar
Jocaren Jocaren is offline
Jocaren is starting off with a positive reputation.
2.5 leveling kit from ready lift works great on mine, i have 35/12.50/18 toyo m/t. I did have to cut some of my inner plastic fender but not too much . i think it has to do with my rims.
Old 07-13-2011, 12:43 PM
Quote:
u should post pics
Old 07-13-2011, 01:19 PM
Pili's Avatar
Pili Pili is offline
Pili is starting off with a positive reputation.
I run the metric equivalent of 35's BFG A/T K/O 315/70/r17. I have an 05 F250 with no lift and they fit fine with no rubbing but the ride quality sucks. It feels like I'm riding in a Sherman tank on most city streets
Old 07-13-2011, 02:56 PM
My truck is a 2005 FX4 Lariat. It does have coils in the front, not leaf springs. What do you tink would be the best way to go? Any thing i should avoid doing?
I have leaf springs so I can't speak from experience, but Stumpbuster is telling you what most coil spring owners say.
Quote:
Originally Posted by stumpbuster View Post
coil spring spacers, 2.5". kit costs 28 bux. doin mine this weekend. did exact same thing 2 years ago. simple, easy, effective, done
Quote:
Originally Posted by Pili View Post
I run the metric equivalent of 35's BFG T/A 315/70/r17. I have an 05 F250 with no lift and they fit fine with no rubbing but the ride quality sucks. It feels like I'm riding in a Sherman tank on most city streets
That sounds like bad shocks or too much air in tires.
Old 07-13-2011, 06:33 PM
Pili's Avatar
My tires are not over inflated but i do think the shocks need to be replaced. It still has those wanna be Ranchos that come with the FX4 package. Only had the truck 6wks and haven't done anything to it except for tinting the windows
Old 07-14-2011, 07:02 PM
petcutz's Avatar
petcutz petcutz is offline
petcutz is starting off with a positive reputation.
2005 2wd 6" Fabtech lift with 35" tires on 17" wheels
Old 07-15-2011, 09:30 PM
ssg510 ssg510 is offline
ssg510 is starting off with a positive reputation.
I also run metric equilivants of 35s with no lift kit and ride is very good. No rubbing and the tires are bfg A/Ts.
Old 07-16-2011, 02:07 AM
CuNmUdF250's Avatar
CuNmUdF250 CuNmUdF250 is offline
CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.
Just put 315/75/16's on my 99 no lift only rubs on inner plastic behind tire they are toyo m/t's measure right at 35" look awesome ride great and aren't loud at all hopefully they will do better than the POS Hankook m/t's I had before
15 f250 lift or leveling kit madcatter33 6.7L Power Stroke Diesel 11 03-07-2016 12:19 PM
Dumb battery cable question luv2offroad2 1999 to 2016 Super Duty 3 05-03-2015 10:07 PM
Tire clearance question MtnGoat 6.0L Power Stroke Diesel 5 06-22-2013 07:12 AM
'97 f350 suspension lift questions warnecke13 1987 - 1996 F150 & Larger F-Series Trucks 13 01-19-2012 12:27 AM
Lift Kit ?? advice luv2huntnfish 1987 - 1996 F150 & Larger F-Series Trucks 10 06-01-2010 01:49 AM
Tags
1997, 2003, 2011, 35, 73, duty, f250, ford, kit, lift, rubbing, running, super, tirerson, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
