more torque with stock muffler or straight through one
Old 07-11-2011, 09:13 PM
Jason302's Avatar
Jason302
Jason302 is offline
I have a 91 f150 with a 302 I want to know will have have more low end torque with the stock muffler or a aftermarket straight design
Old 07-11-2011, 09:19 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
My vote is about the same result. The bottleneck in your exhaust is the factory y-pipe and converters. Replacing them will net you more power throughout the RPM range.
Old 07-11-2011, 09:28 PM
blkfordsedan's Avatar
blkfordsedan
blkfordsedan is offline
I agree...the muffler design doesn't have much effect on the system as a whole. Plus, it depends on the actual flow and exhaust gas velocity. A good turbo style muffler can flow better than a cheap glass-pack with a louvered core.
Old 07-11-2011, 09:35 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
302? torque?
you wont notice anything from a muffler swap except sound.
Old 07-11-2011, 09:44 PM
BIGskinny's Avatar
BIGskinny
BIGskinny is offline
Not to thread hi jack just a quik question. The pass side of the y pipe is smaller then the drivers side pipe. My question is, are the manifold where there the pipe bolts to the same size on both sides or are they different? Thanks
Old 07-11-2011, 11:52 PM
Brettboat's Avatar
Brettboat
Brettboat is offline
I found my truck to be more responseive when I put in a glass pack. But it may be all in my head...
Old 07-12-2011, 09:42 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
either get a bassani Y pipe or have a reputable exhaust shop build you a proper mandrel bent Y pipe. Run a hi flow cat and what ever muffler you like. If you can run long tube headers this will help improve torque on the 302, shorties work as well just not as much. either way the exhaust should be the first upgrade. Just dont expect miracles, the 302 is not a torque motor period.
Old 07-12-2011, 09:54 AM
blkfordsedan
I believe the driver's side is either double wall or has a shield around it since it passes directly under the engine.
Old 07-12-2011, 04:29 PM
shortbus1231's Avatar
shortbus1231
shortbus1231 is offline
i like straight pipe, it lets the engine breathe with a little back pressure
Old 07-12-2011, 04:52 PM
BIGskinny's Avatar
BIGskinny
ten four..just curious cuase im planning on building a y pipe with out the resonator or cat which ever that is right where it ys at..my plan was to just use the left side and just make the pass side but then i saw it was two diff sizes so it kinda threw that plan out the window.
Kapusta
Exhaust Systems
12-22-2015 12:13 PM
Kapusta
15
12-06-2015 01:39 PM
ScumbagSteve
29
12-16-2013 03:20 PM
Jason302
23
07-12-2011 04:24 PM
Quick Reply: more torque with stock muffler or straight through one
