question on Lumi probe Royunda 78.0200
say mates :
I came into a Rotunda timing meter - the lumi probe does not shine light thru it like the Snap On probe for an MT480 - on the greenish side - not sure best how to clean or is I need a new one ( good Luck )
If you can shed some light - appreciate it
cheers in advance
cheers in advance
Say FORDF250 :
Done already - improved it a bit - probably 40 % improvement - but no where near as clear as a new Snap On - so I am asking since this probe is a luminosity probe - the intensity of light will effect the reading -
Why I ask specific to the Rotunda - as I have good Snap On probes - if Rotunda used a coloured crystal as to clear
cheers:
cheers:
I have a Rotunda unit as well. My lumy probe is not perfectly clear. It has some fractals in it but I can still see a goo amount of light through it and when installed into the engine, I can see bright flashes from it. Try installing it into the block and if you can see a clear flash coming from it, try the timing.
Say Eatont999:
cheers for the reply -
Ok good to hear I quess and I will do so as soon as I am ready - just wondering if this Rotunda would handle one of the Snap On probes - or might it be too bright - as if the electronics are set to only read from a more diffused flash
Rotunda probe head is thicker by 2 mm - ish - so I am sure a Snap On probe could be rigged to fit for temp use - but if the flash is too bright for the Rotunda ........
cheers:
cheers:
My best guess would a result from the high temperatures and compression of the engine and mistreatment by previous owners. If you drop the lumy probe on a hard surface, like a shop floor, you can expect the crystal inside to crack or fracture. Unless it is really bad, the light sensor should still be able to pick up a signal.
Althought the lumy probe doesn't directly measure luminosity in this application, it does provide an intensity signal, which has a threshold level at which the meter detects combustion. Since the combustion is a progression of dark to bright, a probe allowing less light through will reach that threshold later and thus report a more retarded timing.
So although its purpose is just to tell when combustion happens, it does depend on light intensity.
A sensor circuit at this level should not be harmed by low to moderate overload, so the best way to find out is to try the different probes with the same engine and compare.
Chevy_Eater
09-24-2014 04:40 PM
nibiru
06-09-2011 06:59 PM
