changing the inner seals on a Dana 60 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-12-2011, 12:44 PM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
Was there a thread on here a while ago about changing the inner axel seals on a Dana 60? I notices it looks like oil on the driver side axel tube end and possibly some oil on the ground under it. I guess I got another project to do. Thanks.
Old 07-12-2011, 03:22 PM
Tom S's Avatar
Tom S Tom S is offline
Tom S is starting off with a positive reputation.
Yes, that thread was just a few weeks ago. I posted on it for searching
Old 07-12-2011, 03:50 PM
arkredneck's Avatar
arkredneck arkredneck is offline
arkredneck is starting off with a positive reputation.
It's a pain from what I understand
Old 07-12-2011, 06:32 PM
BadDogPSD's Avatar
BadDogPSD BadDogPSD is offline
BadDogPSD is gaining momentum as a positive member of FTE.BadDogPSD is gaining momentum as a positive member of FTE.
The third post has some helpful links:
Dana 60 Inner seal - Diesel Forum - TheDieselStop.com
It's not difficult, but it does take time as you have to remove both axle shafts and the carrier. The seals press in from the inside of the differential housing.
I used 2-piece spicer seals and they worked very well. I wish I had known about the outer seals when I did mine as I would have installed those too.
Old 07-12-2011, 09:57 PM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Fullcrew7.3 has a good reputation on FTE.Fullcrew7.3 has a good reputation on FTE.
Craig is right. I just did both of mine 3 weeks ago. Not hard, but takes a few hours for sure.
Old 07-13-2011, 07:06 AM
wildstang's Avatar
VT Chapter Ldr
Thank for the help guys. I probably wont be able to get to it for over a week due to vacation. So you guys didn't need any special tools then.
Old 07-13-2011, 08:30 AM
Just the wheel nut socket.
Old 07-13-2011, 10:41 AM
RRranch RRranch is offline
RRranch is gaining momentum as a positive member of FTE.RRranch is gaining momentum as a positive member of FTE.
Those new style seals don't press in. They are designed so that as the carrier is slid back into place it pushes them in as far as they need to be. Just put them in place at a slight angle so you can start the carrier back in and then push it home. It's a 2 piece seal so it doesn't matter if that end is touching the carrier. I had to make a lot of calls about them after ruining one set and getting pissed off. That's how everyone said to do it. It's been a year and mine haven't leaked.
Old 07-13-2011, 11:16 AM
dclack's Avatar
dclack dclack is online now
dclack has a good reputation on FTE.dclack has a good reputation on FTE.
Be very carefull when you slide the axle shafts back in. You can mess up the new seals and will have to start all over again.
Old 07-13-2011, 05:26 PM
BadDogPSD's Avatar
Quote:
Darn, didn't know that! I made my own press. Copied what Billy (GTXTC2) did and it worked perfectly.
Quote:
Good point!
Old 07-13-2011, 05:59 PM
wildstang's Avatar
VT Chapter Ldr
So can I get the one piece or are the two piece the only ones available? Any place better than Another to get them?
Old 07-13-2011, 08:44 PM
BadDogPSD's Avatar
I used the Spicer 52148 seals. These are the two piece design where the inner part rotates with the axle shaft.
I think the PN for the single piece seals is 36487.
Old 07-14-2011, 06:57 AM
wildstang's Avatar
VT Chapter Ldr
Not sure which would be better. The one piece need to be pressed in but the two piece don't need to be, is that correct? Which Is less likely to get messenger up putting the axel in? Any other advantage to one over another?
Old 07-14-2011, 01:02 PM
BadDogPSD's Avatar
Quote:
Personally, I'd probably still press in the two piece seals. I'm sure using the carrier to press them in works fine, but knowing my luck, I'd screw it up. The press is really easy to make & probably cost less than $10 in parts. I'd offer you mine, but I loaned it out a couple of years ago and never got it back.
The one piece design causes wear on the axle shaft as the shaft rotates.
If you look at an older, high mileage axle shaft, you can actually see where the seal wears away the metal... not much, but it's there.
The two piece design rotates within itself. It presses into the axle housing, and holds tight to the axle shaft.
It's a newer design that's used on the super duties.
I don't think either one is less likely to get messed up when putting the shafts back in, but as long as you're careful and don't force it until it's lined up correctly, you'll be fine.
Old 07-14-2011, 01:25 PM
Tom S's Avatar
I got those seals pressed in but they were a pain for sure.
Help - Dana 60 inner axel seals Vijay 1999 to 2016 Super Duty 9 01-07-2017 11:14 PM
1996 f350 dana 60 axle seals Codymiller 1987 - 1996 F150 & Larger F-Series Trucks 0 03-17-2015 06:09 PM
dana 44 inner axel seals Bigbruce 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-06-2013 08:27 AM
Dana 60 dust shields for brakes wildstang 1994.5 - 1997 7.3L Power Stroke Diesel 6 12-06-2011 06:34 PM
Dana 60 rear axel nut torque specs 79str8six 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-20-2011 12:49 PM
Tags
200, 60, axel, axle, change, dana, duty, f250, f350, ford, piece, replace, replacing, seal, seals, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
