changing the inner seals on a Dana 60 - Page 3 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 05-30-2014, 02:24 PM
Tom S's Avatar
Tom S Tom S is offline
Tom S is starting off with a positive reputation.
Quote:
Originally Posted by LeoJr View Post
There are a couple of threads about this issue so I picked the one that seemed to have the most information.
I ground the metal lip and used the below improvised threaded rod to pull the seal into its seat. No success. My challenge was keeping the outer ring straight. It would get slightly cocked and the metal lip in the inner piece would slip into the outer, deforming it.
I'd appreciate any suggestions on installation. Right now I'm trying to decide if I should just put the old style in or to get another new seal. I have ruined two seals so far and need to improve my installation success.
Thanks in advance!
I think I also had to taper the end of the seal shell to get them started. Where that light blue area is. I just used a thin coat of RTV to replace the moulded on light blue stuff.
  #32
Old 05-31-2014, 11:17 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Ooops,wrong thread.
  #33
Old 06-01-2014, 07:08 AM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Dana has a lot of their service manuals online. I didn't scour it to see if the inner seals are covered in depth, but it should come in handy for reference, torque specs, etc.
http://www2.dana.com/pdf/5309-3.pdf
  #34
Old 09-16-2016, 10:01 AM
mcali2's Avatar
mcali2 mcali2 is offline
mcali2 is gaining momentum as a positive member of FTE.mcali2 is gaining momentum as a positive member of FTE.
Is there a part number or name to get the 2 parts inner seals?
  #35
Old 09-16-2016, 10:34 AM
knottyrope's Avatar
knottyrope knottyrope is offline
knottyrope is gaining momentum as a positive member of FTE.knottyrope is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BadDogPSD View Post
I used the Spicer 52148 seals. These are the two piece design where the inner part rotates with the axle shaft.
I think the PN for the single piece seals is 36487.
Skipped over this one MCali2?
  #36
Old 09-16-2016, 04:07 PM
mcali2's Avatar
Sorcery! That was not there. Magical powers you have.
  #37
Old 09-16-2016, 04:34 PM
mcali2's Avatar
What type of wheel nut socket is needed? I have read about how it takes 3 tries from the auto part stores to get it right.
  #38
Old 09-19-2016, 10:48 PM
kmjone00's Avatar
kmjone00 kmjone00 is offline
kmjone00 is starting off with a positive reputation.
I put a couple pictures here of the two different kinds of spindle nuts I've seen in the hubs. There's a four-prong socket and a rounded hex socket. I believe the four prong lock nut assembly came with factory manual locking hubs and I believe the rounded hex came with factory auto locking hubs. Someone correct me if I'm wrong here.
http://www.ford-trucks.com/forums/14...al-help.html
The two inner seal part numbers I've found are 36487 for the original style one piece and 52148 for the newer super duty style two piece. I gather there's a metal lip that has to be ground off the two piece seal and it's still a bit more work to get it pressed in correctly. Based on a lot of reading here and a few PMs I'm not sure the two piece is worth the extra work, hard to say.
http://www.ford-trucks.com/forums/14...s-52148-a.html
Good luck with the seals.
Help - Dana 60 inner axel seals Vijay 1999 to 2016 Super Duty 9 01-07-2017 11:14 PM
1996 f350 dana 60 axle seals Codymiller 1987 - 1996 F150 & Larger F-Series Trucks 0 03-17-2015 06:09 PM
dana 44 inner axel seals Bigbruce 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-06-2013 08:27 AM
Dana 60 dust shields for brakes wildstang 1994.5 - 1997 7.3L Power Stroke Diesel 6 12-06-2011 06:34 PM
Dana 60 rear axel nut torque specs 79str8six 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-20-2011 12:49 PM
Tags
200, 60, axel, axle, change, dana, duty, f250, f350, ford, piece, replace, replacing, seal, seals, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
