Occasional, repeatable binding from rear axle (I think)
Old 07-12-2011, 10:08 AM
arootbeer's Avatar
arootbeer
arootbeer is offline
On my new-to-me (3500 miles of my own, 101k total) 2000 excursion, I have encountered a weird behavior which seems to be coming from the rear end.
After more than a few minutes cruising at speed, if I come to a complete stop, the rear end will bind up on launch. The torque converter spins up and stalls, and then the truck will crawl forward until it unbinds, at which point it will lurch forward and drive completely normally. If I'm driving stoplight-to-stoplight, or even at speed for just a minute or two, it doesn't happen; I'll come to the stop, and just launch normally.
I do have a leak from somewhere around the front pinion seal, but it's just weeping. I had the fluid in the diff topped off before my highway run yesterday (~600 miles), and the tech said it only took a pint. Unfortunately I didn't think to ask whether that was to the hole, or just to whatever the "full" level should be.
Following the advice in this post:
Originally Posted by CrzHelm
looks like the rear pumpkin has oil stains. is it leaking from the pinion bearing? that oil can a be sign of a worn pinion bearing and you have excessive gear backlash or worn pinion splines. chock the wheels, put he trans in neutral, go under and turn the rear driveshaft by hand back and forth. if it moves excessively without turning the wheels then that could be the bang youre getting. there is supposed to be bump stops on the end of those anti wrap springs too. also check the u-joints while your at it.
I checked the play in the pinion bearing. There is perhaps 4 or 5 degrees of play; I can definitely feel it rock from one side to the other, but it doesn't feel excessive at all.
Anybody run into this before? Thoughts?
Old 07-12-2011, 02:30 PM
wpnaes's Avatar
wpnaes
wpnaes is online now
That play of 4 degrees isn't a big deal IMO (shaft turns 4 deg before engaging the ring gear). Are your drive shaft U-joints ok? No excessive play there? The seal is a relatively easy fix, but focus on solving the binding issue before diving into the leaky seal. If U-joints are OK, crack open the differencial, drain the oil and see what's binding in there.
Old 07-12-2011, 04:10 PM
arootbeer's Avatar
arootbeer
Is it possible for the pinion bearing to be off its axis and binding that way? I'll check the u-joints, but what should I look for? I don't see how they could cause binding.
Thanks for the suggestions!
Old 07-12-2011, 04:25 PM
jasonodsky's Avatar
jasonodsky
jasonodsky is offline
Could it be low transmission fluid? Seems like the TC may be winding up to get enough pressure to apply power, then dumping the force of the higher RPM motor straight into the rear end. Could be a sign of low transmission fluid.
Is yours the diesel or the V-10 gasser?
Old 07-12-2011, 10:39 PM
arootbeer's Avatar
arootbeer
Transmission fluid is full; checked that last week. It's a 5.4 4x2.
Old 07-12-2011, 10:46 PM
wpnaes's Avatar
wpnaes
Pinion would have to be super loose. When you take off the rear driveshaft to check that U-joint, can you pull the pinion flange in and out (forward and backward)? U-joint will be sloppy and might have rusty residue where the cap meets the joint caused by no lube on the needle bearings. They can get squeeky too.
Some pics at the end of this thread.
https://www.ford-trucks.com/forums/1...nion-seal.html
How about a dry driveshaft slip joint?
Old 07-12-2011, 11:36 PM
arootbeer's Avatar
arootbeer
Here are some pictures of the u-joints; they're rusty and have a dirt build-up at the joints, but look like I'd expect them to.
Rear with picture of the pinion seal
https://picasaweb.google.com/lh/phot...SfhiIpISOmSEmQ
Some detail of the rear
https://picasaweb.google.com/lh/phot...S2M2J-fAJinCfw
Some detail of the front
https://picasaweb.google.com/lh/phot...gvV476jfz_1hqg
In the third picture, the black stuff appeared at first to be metallic. However, upon physical inspection it is just essentially baked-on grease. The same basic condition on the rear joint. Are the U-joints serviceable at all, or are they sealed?
Where is the driveshaft slip joint? My driveshaft is solid - one piece from the front u-joint to the back.
Old 07-13-2011, 06:52 PM
wpnaes's Avatar
wpnaes
Apparently your 2wd has a little different set up than my 4wd. I'm thinking the 3rd picture grease came from that u-joint- worth checking further off the truck. Looks like that's the u-joint near the tranny? It's connected with a slip joint into the tranny rather than on the shaft like mine (you saw my pics right?). Before you pop off the drive shaft, jack up a rear wheel (safely) and turn the driveshaft by hand (Tranny in N, blocked tires so she won't roll over ya) both directions. See if you can duplicate that binding by hand. Turn a wheel by hand also see if it binds. Hang in there, we'll get 'cha sorted out.
Old 08-25-2011, 10:41 AM
arootbeer's Avatar
arootbeer
I finally got the truck in to the transmission shop (a different branch) a couple of weeks ago, and they went completely through the tranny - pulled it apart, found nothing physically wrong with it, added a line pressure increase kit, and put it all back together.
The guy at this branch had told me when I brought it in to get it diagnosed that it could be something as simple as an incorrect torque spec on one of the valve body bolts - I assume this would cause leaking between the valve body channels and therefore incomplete engagement. Since it was put back together, I have not experienced the slipping (which is what I'm now convinced it was).
Thanks for all the help and ideas - I've now got a better running truck and a better understanding of the driveline.
Thisguy65
19
06-08-2017 11:44 AM
427 fordman
22
06-06-2016 08:00 PM
TonyJestis
15
11-05-2012 06:13 PM
cajunsuperduty
03-05-2012 12:13 PM
nhill2090
05-07-2011 09:41 AM
Quick Reply: Occasional, repeatable binding from rear axle (I think)
