Idler Pully Replacement - Ford Truck Enthusiasts Forums
Old 07-11-2011, 08:03 PM
dwild dwild is offline
dwild is starting off with a positive reputation.
Hi
The Idler pully is shot on my 2003 5.4L 4x4 Off road model. The question I have is, can I replace this pully without removing the serpentine belt? The belt does not go around this pully, it only rubs against it.
I am thinking I can have a helper relieve the belt tension, while I remove the old one and replace the new one. Does this sound like a plan? Will the belt fall off any of the pully's when I relieve the tension?
On another note, is there a special tool I need to replace the belt just in case I do need to remove it?
Thanks
Dwild
Old 07-12-2011, 09:04 AM
d5332 d5332 is offline
d5332 is starting off with a positive reputation.
Remove the belt, follow the diagram under your hood for re-installing the belt.
Rent the special tool from your local chain auto parts store.
Old 07-12-2011, 03:02 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Take the tension off of the belt.
I use a breaker bar for that.
Slip the belt off of the pulley.
(This is when I would go ahead and change the belt too.)
Replace the idler pulley.
Reroute the belt into place.
Old 07-12-2011, 03:14 PM
93 mix 'n match's Avatar
93 mix 'n match 93 mix 'n match is offline
93 mix 'n match is gaining momentum as a positive member of FTE.93 mix 'n match is gaining momentum as a positive member of FTE.
wtf? special tool? i just replaced mine not to long ago. its not like you have to completley remove the belt, just slide it off the alternator and bam, access to the idler pulley.
Old 07-12-2011, 03:51 PM
The tool is special bc it provides leverage...so yes, its a special tool, if you have a breaker bar that can work too
Old 07-13-2011, 12:33 AM
Idler Pully Install
There is not much to slip off, the idler only rubs up against the belt on this 5.4L motor.
This is why I think this may be possible with a helper holding the breaker bar.
Dwild.
Old 07-13-2011, 02:01 AM
BFTUFF BFTUFF is offline
BFTUFF is starting off with a positive reputation.
It's simple. You just have to remove a little tension off the S- belt and the idler pulley can be swapped out. There is no need to remove the S-belt unless your removing the tensioner and replacing that, then you will have to remove the S-belt. Getting that serpentine belt on an off with just two hands is a little tough though.
Old 07-13-2011, 02:18 AM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Quote:
Who doesnʻt like buying tools.
Although I donʻt have this particular tool, I created one to do this task.
BTW, having this special tool whether bought or made helps on different model cars and trucks.
Removing a serp belt on an older Taurus or a Windstar needs this type of tool.
Once you take tension off the serp belt, the rest of the job should be a snap.
Just keep you hands clear from in between the belt and pulleys when replacing the belt.
Old 07-13-2011, 07:46 PM
pommesdeux's Avatar
pommesdeux pommesdeux is offline
pommesdeux is starting off with a positive reputation.
Take a 1/2 drive bar loosen and remove the belt and replace the stock bearing with a $ 2.00 6203-2RS bearing (think that's the number) and reuse your Idler wheel. Pop out one of the rubber seals and pack it with a good synthetic grease replace and way to go, 20 min done.
Possible belt tensioner pully bad JimG1098 2004 - 2008 F150 2 10-01-2015 11:57 AM
Double Water Pump Pully Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-23-2014 10:18 AM
6.4l Serpentine belt chirp noise makuloco2000 6.4L Power Stroke Diesel 5 09-22-2013 10:40 PM
serpentine belt remove/replace tonyhd 1997 - 2003 F150 9 04-01-2011 10:25 AM
92 IDI Serpentine Belt Squealing on Idler Dieselguy89 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-23-2008 01:05 PM
Tags
1986, 1997, 2003, 46, 46l, 50, 97, belt, f150, ford, idler, installation, location, pulley, pully, replace, replacing, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
