1944 1 1/2 ton ford fire truck worth anything? or scrap - Ford Truck Enthusiasts Forums
Old 07-11-2011, 04:12 PM
1BIGBURB85 1BIGBURB85 is offline
1BIGBURB85 is starting off with a positive reputation.
i work at the amherst museum in western new york and have been asking my boss about this truck thats slowly rotting away in there feild, he told me today that if i get it out of there i can have it. i origonaly was going to scrap it but thought it would be neat if someone did somthing with it, its a 44 ford and belive its a 11/2 ton fire truck is this worth trying to sell or should i send it too the bone yard?
Old 07-13-2011, 01:57 AM
Chaosracing's Avatar
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.Chaosracing is gaining momentum as a positive member of FTE.
From what I can see in the picture, it looks to be in decent shape. If it were me, I would pull it out and inspect the whole thing. But from where I see it now, I would take the time and fix it up. Not to many of them around, especially 44's due to the war effort. As far as value, its only worth what someone will pay for it. Especially if it has a title or not. But the parts alone are probably worth more than if you took it to the scrap yard. Not sure the condition of the jailbars, but those are one of the hardest things to find. In fact, if you do decide to part it out, please let me know as I have a 1 1/2 ton I am going to be redoing and need stuff like the jailbars and a few other parts.
Old 07-18-2011, 03:06 AM
gilasailr gilasailr is offline
gilasailr is starting off with a positive reputation.
I am looking for a straight front bumper - blade only - if you decide to 'liberate' the truck.
Everybody with 42-47's is looking for grille bars ! Myself included!
gilasailr@aol.com
Old 05-20-2014, 06:58 PM
42VeeAte 42VeeAte is offline
42VeeAte is starting off with a positive reputation.
I realize your original post is older, but I figured I'd send you a note on the off chance you are selling parts from this truck.
I'm looking for a toggle-type ignition switch, which Ford used from the middle of WWII until the end.
It is located right next to the temp gauge in this reference shot:
If you have this switch and would like to sell it, feel free to send me a PM.
Thank you.
Old 05-24-2014, 03:16 PM
1952henry's Avatar
1952henry 1952henry is online now
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
Thank you.
All (or nearly all after 1941) WW2 vehicles used this switch. Try Vintage Power Wagons, or G503, or similar sites. Shouldn't be too hard to find one. You can get these new, I think I got one at a large truck parts place. It was chromed, and had some numbers on it, but after a date with a wire wheel on a grinder, and some filing, it was ready for od paint.
DPF system 69mstng 1999 to 2016 Super Duty 14 05-15-2016 09:47 PM
'58 F600 fire truck GB SISSON 1957 - 1960 F100 & Larger F-Series Trucks 37 11-27-2015 11:55 PM
Vintage camper shell 51PanelMan 1948 - 1956 F1, F100 & Larger F-Series Trucks 86 05-06-2015 06:24 PM
Scrappin an '85 Lance Skene Bronco II 12 02-11-2015 12:43 AM
1951 F7 fire truck $cheap jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 04-17-2011 10:56 PM
Tags
12, 1944, 19671972, 1972, 1980, 2011, antique, anythnig, engine, fire, firetruck, ford, spec, ton, truck, trucks, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
