Heater Control Valve Question - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 07-11-2011, 04:51 PM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
YES, I know it's summer but, still...
While diagnosing a problem with my rear AC not working, I pulled the rear plenum apart. I noticed the rear heater coil was really hot even though I did not turn the heat on at all that day.
I suspect a bad heater control valve. The one that stops hot coolant from going to the core when the AC is on. I have manual temp controls so I assumen it is vacuum controlled. Alldata does not give me a loction or vacuum routing specs for the valve so I am asking here.
1) Where do I find the heater control valve? Anyone have a picture?
2) Does it shut off the coolant to both the front and rear heater cores or just the front?
Thanks!
Old 07-11-2011, 06:15 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
If you have a heater control valve, you should be able to find it fairly easily in the engine compartment. Trace your heater hoses, and look for the valve. The vacuum line may have come off of it, causing your hot coil issue. One valve should shut off the flow from both front, and rear coils.
My 04 is a diesel and the valve is on the passenger side of the engine compartment, back towards the firewall, with a small grey vacuum line attached to it.
Old 07-11-2011, 08:07 PM
wpnaes's Avatar
wpnaes wpnaes is online now
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Jason, check on the passenger side. I used this to fix my 'no heat' situation, but I never did check the rear heat (just camping gear back there and it doesn't complain)
Disconnect the hoses gently else get coolant everywhere and down those cops!
Sean
While you're in there scraping knuckles clean up the PCV - (pic 3 stinkin' coolant everywhere.)
Old 07-11-2011, 08:52 PM
jdw1's Avatar
jdw1 jdw1 is offline
jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.
What exactly do you do there?
Old 07-11-2011, 08:54 PM
Sean
I'm guessing you're in Anaheim, Sean.
Old 07-11-2011, 09:22 PM
wpnaes's Avatar
Quote:
Veggies at work, but prefer camping.
Quote:
Live in Camarillo, check Trey's map (So Calif Chapter).
Old 07-11-2011, 09:41 PM
I was thinking "Where in So C"......
Nevermind.
Great post and pics
Old 07-12-2011, 11:14 AM
jasonodsky's Avatar
Thanks Sean and william_04_x. It was really obvious to find once I looked . My '04 has the electrically heated PCV so there is no heater line going to it. I just replaced the PCV last week.
The '04 in line valve is still vacuum acuated but there is actually an arm and diaphram I can watch actuate when I change from AC to heat. I moved it a couple of times manually and then tested it from the cabin switch. It moved as expected but since I disturbed it before checking it from the cabin, it could have been stuck.
I'll do some testing and check the temp of the line behind the valve to see if it is getting hot and possibly leaking past the valve. I'll also clamp the hose and see if that changes things. I'll try to post a pic of the '04 version of the valve later today.
Old 07-04-2016, 04:37 PM
WeldWerx WeldWerx is offline
WeldWerx is starting off with a positive reputation.
Sean
So does the flap stop the coolant from going out the bottom of the fitting? Trying to figure out which line to put a shut off valve in...and yes I've searched and searched so this is a last resort. Thanks.
Old 07-04-2016, 04:45 PM
wpnaes's Avatar
My guess is the bottom hose goes to the rear heater in the Ex. The upper left
one goes to the front passenger heater. I've never investigated this though. The one valve controls both heaters.
I was replacing this valve yearly with cheap parts; since I used a Ford part, haven't had any issue for a couple of years.
Old 07-09-2016, 11:38 AM
i could probably replace mine, but my ac isn't too cold, I was just hoping if I cut the coolant off to the front heater core it would improve a bit, I just don't want to put a manual valve on the wrong line.
Old 07-09-2016, 01:59 PM
Vwags's Avatar
Vwags Vwags is offline
Vwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to beholdVwags is a splendid one to behold
Quote:
I went/am going through this very thing. It drives me crazy that the vehicle just doesn't seem get that cool. Then the other night we were driving home at about dusk, it was still about 95 outside and I noticed the ac seemed cooler. I think we have so much surface area that the sun has a huge advantage. Now I am thinking about ceramic window tint again.
Old 07-09-2016, 02:37 PM
wpnaes's Avatar
http://www.ford-trucks.com/forums/13...l#post15048442
Give your fan clutch a check, if it's not working on a hot day, that a/c will never be cold.
Old 07-09-2016, 03:33 PM
05MilMachine's Avatar
05MilMachine 05MilMachine is offline
Frequent Fueler
05MilMachine has much to be proud of05MilMachine has much to be proud of05MilMachine has much to be proud of05MilMachine has much to be proud of05MilMachine has much to be proud of05MilMachine has much to be proud of05MilMachine has much to be proud of05MilMachine has much to be proud of05MilMachine has much to be proud of05MilMachine has much to be proud of
The heater control valve only gets vac when on "MAX A/C" any other settings it opens up. My black truck in the Texas heat takes quite a while to cool down if I don't crack the windows while parked. After a few miles on the freeway though, its blowing nice cold air. I think its just the size of the greenhouse we drive around.
Old 07-09-2016, 05:49 PM
Quote:
mine is need of a re-tint, but I've popped the heater core box open when on max ac and that ting is red hot so I just want to keep the air blowing through the vents from starting at a 190-200* disadvantage.
Heater control Valve ? ExBeast Excursion - King of SUVs 0 07-13-2016 05:24 PM
Heater Control Valve vanman23 Excursion - King of SUVs 3 07-11-2014 04:27 PM
Poor AC performance in '09 F-150 Bret (OH) 2009 - 2014 F150 12 07-06-2012 11:58 AM
Do the 06 F150s have a heater control valve? eallanboggs 2004 - 2008 F150 4 12-13-2010 01:26 PM
Rear A/C blowing hot air Schlump 1987 - 1996 F150 & Larger F-Series Trucks 2 02-27-2003 06:50 AM
Tags
03, 2004, 460, automotive, control, controlled, controls, diagram, e350, expedition, ford, heater, line, vacuum, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
