You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
It will depend on what crossmember you have installed. I used these tubular mounts from Fatman Fabrications. Later on I added some extra gussets that are probably not necessary, but it made me feel better:
I can't speak for the different kinds of mounts and crossmembers, but the biggest issue for the 302 is trying to keep the front sump on the dual sump oil pan from hitting the steering rack. I had to shim mine up. Search for a thread called something like "recurrent problem 302 oil pan hits steering rack" and read it. We talked a lot about mounts too in that thread. I would find it for you but my phone wont let me search.
__________________
Shane
1949 F1, Stock / 1950 F-5
1950 F1, 302, AOD (still in a lot of pieces)
1997 F150 XLT, 4.6L
2008 F250 XLT, 6.4L Powerstroke
2011 Expedition EL
Reason: Stupid phone changed "sump" to "dump". I hate these things.
i used the mounts from tci and the stock ford motor mounts and still had to shim it with a 1/2 inch flatbar on top of the ford rubber mounts. worked out fine.
The oil pan was definitely a problem. I bought a rear sump oil pan and was able to put my engine in. You can see the work in the pics below.
I notched out the original tranny cross member but ended up cutting it completely out. The first exhaust I was going to put in wouldn't fit with it in there. Then I switched to shorty headers, but had already cut out the cross member.
HELLO FROM ENGLAND/UK
WOULD YOU BE KIND TO SEND ME PHOTOS OF THE FRONT CLIP FITTED IN YOUR 51,,,INCLUDING SHOTS SHOWING THE CHASSIS AND WHEELS FROM SIDES,, I AM FITTING A FRONT END ON MINE AND NEED SOME REFERENCES TO BASE ON IT..MANY THANKS
LORENTE LONDON UK
I don't have any pics of the front clip in place....& it is apart right now. I'll dig up some pics of the brakes etc. & try to give you a reference point for crossmember location.
Maybe someone else has some pics that they can post today. Are you trying to set the front axle back to center the wheels up in the wheel wells?
Here's the only one that I have that might have a reference point. The MII crossmember was already installed on the chassis that I bought from Ilya. I did mock up the fenders and the wheels will be more centered in the wheel openings than stock. This pic show the relationship of the crossmember to the original engine mounts (those are gone now). I can take a few measurements if you need some detailed placement information.
