lift kit questions - Page 5 - Ford Truck Enthusiasts Forums
lift kit questions
  #61
Old 07-28-2011, 08:46 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Quote:
Originally Posted by jjoyce11 View Post
Im not opposed necessarily but I just don't think putting a leveling kit on it is going to achieve the look I am wanting. If there wasn't safety, price, and all the other down falls to big lifts I would honestly get a 8 inch. BUT knowing that lifting the truck isn't necessarily the best for truck and really expensive and impossible to park in garages here in CO and such I am not going with the the 8 inch. I think the leveling kit would look nice however, I think I may be disappointed in it and then decide to raise it. at that rate, i would have waisted money leveling it and could have put it toward raising it. when I bought the truck I knew I wanted to lift it. I am going to research it a bit to see my option, im opened minded. there is a truck that often parks next to me at the station and he has a f150 as well and its leveled. When I first saw it i liked it but the more i have been researching lifts and I look at his I just dont think it will satisfy me. Believe me, I wish it did but as I always tell my friends, "go big or go home" if I were to put a leveled truck with 35 and a 4'' lifted with 35 side by side where am I going to see the biggest difference? the space between the tire and the truck right?
If you were to eye-ball it side by side, the 4" kit will have more tire clearance in the wheel wells, and the 4" kitted truck should be sitting 1-2" higher depending on the level kit the other truck had.
  #62
Old 07-28-2011, 11:46 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
OK if you installed a 4" kit with 33" tires no you would not need to upgrade the gears in your truck. With 35's it would certainly help it and give back power that is being lost from pushing a larger tire.
Now on to the leveling kit. I installed one last year in my truck and for a while was happy with it. But was never in love with it I have realized now. So I plan to remove the leveling kit and put on a 4" lift kit.
I will be doing it in stages though. So in the next few weeks I will purchase some new wheels and have them installed. Then in a few months I will hopefully get the kit on right after the new year.
  #63
Old 07-29-2011, 05:26 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
With 33s, and depending on your rear end gear:
if you have a 3.73 IMHO you will be fine
if you have a 3.55, you are right at the limit of needing to re-gear (I would just to help save the tranny)
if you have a 3.31, you need to re-gear
Regardless, you will need to re-program the PCM for the larger tires.
  #64
Old 07-29-2011, 01:34 PM
jjoyce11's Avatar
jjoyce11 jjoyce11 is offline
jjoyce11 is starting off with a positive reputation.
I will keep an eye out for the changes and hopefully it will help me decide on mine. I think I will feel the same way as you do. the level is nice, but not good enough. I am going to finish paying off the truck then invest in the lift/level
  #65
Old 07-29-2011, 01:42 PM
jjoyce11's Avatar
thanks for the info. ill have to do a little research, I just looked at the owners manual and I couldnt find what my IMHO is but I will definitely check it out. and yes, i can re-program the PCM myself with the help of a family friend.
  #66
Old 07-29-2011, 01:55 PM
MCDavis's Avatar
IMHO = in my honest opinion
That won't be in the manual Jodi. Charlie meant to say that if you have a 3.73 gear (which you should if you have a true FX4) then you'll be ok, in his honest opinion.
  #67
Old 07-29-2011, 01:58 PM
jjoyce11's Avatar
hahah got it. I thought there wasnt something right or I was just reading it wrong. I asked my dad and he had no idea either but thanks for the correction. yes mine is a true fx4 so yipeee im safe!!
  #68
Old 07-29-2011, 03:32 PM
rockstate45 rockstate45 is offline
rockstate45 is starting off with a positive reputation.
3.73 will do just fine handling a 33. The gears in the transmission should make it just fine for handling a 35" too, but it'll be a little slower. Rotational mass is killer on things like this.
-rockstate
  #69
Old 07-29-2011, 03:41 PM
jjoyce11's Avatar
Quote:
-rockstate
well we all know i have learned a lot but im still need a bit of help! i understand that when you upgrade to bigger tires it takes longer to stop and to start as well as it slows the truck down in general when driving. What do you mean by rotational mass is killer on things like this? is it just the wear and tear on the truck from having to work harder to rotate the tires or is there more to it? thanks!
  #70
Old 07-30-2011, 09:12 AM
Well rotational mass is to some extent "heavier," or at least has more effect than static mass... in other words, 50 extra lbs in tires and wheels is going to act differently then 50 lbs in the bed of the truck.
Some new '11 TUndras have had problems with the steering rack blowing b/c the power steering pump surges and blows a seal at full lock in, typically, reverse. The fix? Put in a remann'd '07 pump. This happens on stock trucks as well. This is one example of where this extra weight doesn't act as your friend.
However, the Fords are pretty solid so as long as you're not constantly burning out you'll be just fine with getting this truck along. I've had heavy all terrains on myt ruck for 50k miles... and 13k miles of those being heavy, almost 35" tall all terrains. No biggie there.
Again, this is all my opinion, so take it with a grain of salt.
Why not make your truck into a baja truck? Do a long travel suspension or some mid range setup... upper control arms, shocks, etc...
-rockstate
  #71
Old 08-18-2011, 01:48 AM
Fx4hunter05 Fx4hunter05 is offline
Fx4hunter05 is starting off with a positive reputation.
Thanks for posting this thread! I just bought an 05 fx4 with a short bed last week and was looking into a bunch of upgrades, one of the biggest would be a lift. All the info shared on this site is amazing! While looking for a truck I test drove a truck that had a 6" lift, or so the dealer said, and I loved how the truck looked, but they wanted way to much for it. Thank you guys and gals for your info on the subject
  #72
Old 08-18-2011, 07:11 PM
jjoyce11's Avatar
Quote:
good decision on the truck choice, great minds think alike. anywho, im glad you found the thread useful. it has definitely helped me out a lot. I take it your going to do a 6'' lift?
  #73
Old 08-21-2011, 07:44 PM
Im not sure yet, i was thinking about a 4 inch lift, but I would also like to be able to switch out to my stock wheels and tires as well, plus I can't get over how well the truck rides right now, I have been in some lifted trucks and the ride usually is worse than the stock setup. I'm not sure yet.... I think I'm going to put some fender flares on it first. I will probably be doing a bit of towing with it as well. I have heard alot of people say everything but a true suspension lift changes the factory angles, what would that change as to wear and tear on the steering and handling?
  #74
Old 08-22-2011, 09:19 AM
Coskid's Avatar
Hey wanted to update this with something I recently found. I have been looking for a 4" lift for a while now and for some reason missed one important lift. The Rancho 4" lift. This kit requires you to by the shocks separately but has front shocks not strut extensions. Plus it has a 1 piece sub-frame and allows you to keep your stock wheels until you can afford new ones down the road. Every other kit I looked at had strut extensions for the front end which i was not crazy about for the full suspension lift.
  #75
Old 08-22-2011, 08:46 PM
jjoyce11's Avatar
good find, I will be looking into it. What are your other top picks for brands in the lift? I was told to go with fabtech but I was just on their site and it looks as if they only have a 6'' lift. Also, what is the advantage to having new shocks in the front vs. using struts?
cheapest place to buy suspension lift kit steve33444 1987 - 1996 F150 & Larger F-Series Trucks 30 12-16-2014 11:06 PM
1976 f150 lift kit help Mighty Mustang 1973 - 1979 F-100 & Larger F-Series Trucks 14 10-21-2014 01:44 PM
6 or 4 inch lift with 33s 86fsbronco 1978 - 1996 Big Bronco 20 04-02-2014 02:12 PM
Tire sizes corvetteracin350 Offroad & 4x4 119 03-08-2011 06:21 PM
Just got a set of 35's nicksgt 1999 to 2016 Super Duty 16 01-11-2007 04:18 PM
Tags
2005, 2006, 97, f150, fi50, fit, ford, inch, kit, leveling, lift, sale, size, suspension, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
