99 F250 powerstroke battery drain over night - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-11-2011, 03:03 PM
Derek033 Derek033 is offline
Derek033 is starting off with a positive reputation.
I have a 99 f250 powerstroke. I have tested for a parasitic load and have come up with 99 mA. When i pull fuse 15 of the instrument panel fuse block the load goes down to 10 mA. The only problem is that there is a lot of things that fuse feeds like the stop lamp switch, GEM, PCM, ABS module, brake shift interlock and PCM keep alive memory. I am having a hard time figuring out where to start and how to trck down the cause of my problem. i dont have a service manual so any help would be greatly appreciated. Thanks
Air bag circuit draining battery on 99 F250 Blown 331 1999 to 2016 Super Duty 3 03-29-2014 03:21 PM
Fuse # 19 keeps frying trike1946 Electrical Systems/Wiring 5 10-12-2010 06:44 PM
Battery Drain normn7337 1999 - 2003 7.3L Power Stroke Diesel 4 05-13-2009 06:42 PM
Need help fast, where is my PCM? 05 F250 V10 GT4point6 Electrical Systems/Wiring 3 10-19-2008 06:04 PM
99 Expy low battery elbuencarlos 1997-2006 Expedition & Navigator 4 11-02-2004 05:23 PM
Tags
1999, 99, battery, diesel, drain, draining, drains, duty, f250, fast, ford, overnignt, parasitic, powerstroke, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
