Everything's loose...turbo/up-pipe/y-pipe won't budge!
Old 07-11-2011, 11:43 AM
AndeyHall's Avatar
AndeyHall
AndeyHall is offline
OK, here's what I got....everything is off except the up-pipe and y-pipe. All three bolts came out piece of cake, and the IC tube is off, the air filter pipe is off, and the oil supply line is off, and the marmon clamps on the y-pipe and up-pipe are completely loosened but I can't get the turbo or either pipe to budge. What do I need to do?
Old 07-11-2011, 11:50 AM
High Binder's Avatar
High Binder
High Binder is offline
I had to use a pry bar to lift the turbo from the passenger side. it slides down on the posts of the pedestal just right to make it so that you have to lift it straight up about an inch to get it over one of the bolt posts and then it'll come out. It's not easy but you just have to battle with it a bit. It's way worse going back in, took me a few hours to get mine back in...
Old 07-11-2011, 12:12 PM
AndeyHall's Avatar
AndeyHall
Should the up-pip and y-pipe come out or do they just clamp flush?
Old 07-11-2011, 12:16 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
they clamp flush most of the time but do what he said i always have had to pry mine up. little trick when installing the ypipe back onto the turbo use a ratchet strap on the ypipe and hook the other end to the p side somewhere and slowly ratchet it to the turbo. the pipe will fall right into place!
Old 07-11-2011, 12:29 PM
AndeyHall's Avatar
AndeyHall
awesome idea! i'll give it a try.
Old 07-11-2011, 12:58 PM
High Binder
Good idea!
Old 07-11-2011, 01:53 PM
wulfman's Avatar
wulfman
wulfman is offline
When you say the clamps are losend do you mean the bolts are lose or are the clamps floppy lose so you can move then around if not they have to be .
Old 07-11-2011, 01:55 PM
AndeyHall's Avatar
AndeyHall
It came out. It was the pipes suctioned to the turbo that was holding it in. I took a flat head screwdriver and tapped it against the connections and they popped off and it came right out. Turbo tango wasn't bad at all either. Now how do I get the housing apart? Clamp is completely off and it is sealed TIGHT!
Old 07-11-2011, 02:11 PM
mixerdrvr's Avatar
mixerdrvr
mixerdrvr is offline
Hold it up by the upper section and tap the bottom section it gently! It will come apart easily.
Old 07-11-2011, 02:32 PM
wulfman's Avatar
wulfman
wulfman is offline
Did you mark the position of the clamp and mark the two half's with a punch so they go back in the same way they came apart.
Old 07-11-2011, 03:46 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
i hope he did because if not thats gonna be a nightmare! atleast on the 05-07 turbos they have a pin to help guide them
Old 07-11-2011, 04:39 PM
AndeyHall's Avatar
AndeyHall
I marked the position of the housing and everything went back together pretty nicely. But I didn't think to mark the position of the clamp. Does it have to be precise? I can tell about where it goes from the pictures in the cleaning write-up though.
Old 07-11-2011, 05:25 PM
JESTERxHEAD's Avatar
JESTERxHEAD
JESTERxHEAD is offline
the housing mark is WAY more important than the location of the clamp....just put the clamp back in the same general direction/area.
Old 07-11-2011, 07:56 PM
johnthoms's Avatar
johnthoms
johnthoms is offline
Don't forget about antisieze on all the clamps and flanges , makes everything go soooo much smoother
Old 07-11-2011, 10:32 PM
AndeyHall's Avatar
AndeyHall
Yeah I use something similar that we get from a vendor at my work.
cookingguy
04-02-2017 12:55 PM
kruc
26
08-09-2016 11:46 AM
texastech_diesel
02-26-2016 09:58 AM
NYC F-350
01-05-2013 12:59 AM
tjbeggs
11-11-2005 09:03 PM
Quick Reply: Everything's loose...turbo/up-pipe/y-pipe won't budge!
