Does your a/c suck?
i replaced my compressor myself when i first bought my truck. the pulley on the old compressor separated and was just rubbing on whatever was holding it together. i got the retrofitting kit and pumped it up with r134a and the a/c will freeze you out of the truck. never replaced a dryer or anything. i must be lucky
I wish I had A/C, mine leaked out before I bought it. I really want A/C because I do alot of highway driving and I want to listen to the radio. Kind of hard to do both at 75mph with the windows rolled down.
I still have to get the conversion.
But the compressor still works! It cycles on and off so I'm glad I don't have to replace that.
I just got done with redoing the A/C in my mother's '94. I replaced the compressor/clutch, accumulator, orifice, all O-rings, low pressure clutch cycle switch, and the recirculation door actuator/lever plus vacuum pot. I removed the evaporator and cleaned it thoroughly inside and out. I flushed the lines, evaporator, and condenser relentlessly with A/C flush solvent.
Pulled vac for 2 hours then charged to factory spec with R134a. Works very well, with low side around 40 and high around 280 (automatically adjustable orifice). Set to "Normal" and "Lo" fan in 107F keeps the cab comfortable. Crank it up and prepare for your nipples to hurt.
1) If the system wasn't ruthlessly flushed, cleaned, and dried, FUBAR.
2) If the accumulator/dryer wasn't replaced, FUBAR
3) If the condenser is full of crap (small stones, bug guts, etc.) clean it out. Comb the fins if need be.
4) Reman compressors are hit-and-miss. Some I've had work well, others not so much. I'm a little wasteful now and so long as the price isn't just insane I'll spring for brand-new compressor/clutch. This one was from O'Reilly Auto and was $235, included the compressor and clutch assembly already shimmed and made with all-new components.
It sounds as if your compressor and/or clutch is failing. Doing the job right will take you about $400-500 (plus tools if you don't have them). Paying someone to do the job right will take a lot more.
hrvat
45
03-17-2016 09:41 PM
Hound Dog Lew
03-12-2016 04:31 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
01-03-2016 08:48 AM
hackdog
1997-2006 Expedition & Navigator
05-21-2014 07:23 PM
