New truck, antifreeze leak - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-20-2014, 08:39 PM
sanchezp_09 sanchezp_09 is offline
sanchezp_09 is starting off with a positive reputation.
Quote:
Originally Posted by EO2SeaBee View Post
If the core is good, I wonder if a good radiator shop can build and weld on custom aluminum tanks in place of the plastic ones. Even if the price ended up being as much as a new unit from Ford, I would pay for the peace of mind knowing that the plastic was replaced by welded aluminum.
I have the ESP its just 100$ for a new radiator (1900$ parts and labor).
EO2.. NMCB? Im with 14.
  #32
Old 02-20-2014, 08:48 PM
EO2SeaBee's Avatar
EO2SeaBee EO2SeaBee is offline
I'm Deplorable
EO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputation
I too have ESP, but there are a lot of guys out there that have to cough up the cash to get this fixed. The apparent lack of an aftermarket solution so far has me wondering about modifying the existing one to make them better.
I was with NMCB 24. Spent 5 months in the sandbox in '90-'91.
  #33
Old 02-24-2014, 07:38 PM
runtowin runtowin is offline
runtowin is starting off with a positive reputation.
Angry 2012 F-250 radiator leak
My truck is having the same issue with the radiator leaking on the driving side right off the plastic tank. I'm 3000 miles over warranty with no ESP plan (I am purchasing ESP plan in the morning). Apparently Ford needs to post a TSB (Technical Service Bulletin) on these radiators. I've had TWO dealerships tell me this problem is a very common problem!! One dealership told it was going to be $1700 & the other dealership, at first, said it would be $1500 but would call Ford to see if they could get some financial help! The dealership called back and said it would be only $900, basically cutting out the labor charge!! Ford has the parts market cornered because no aftermarket parts available yet!! Well, after reading on the radiator topic on this forum page and a few others forum pages and by the word of two different dealers that's its a common problem, I believe the radiator manufacturer need to re-evaluate their product or Ford need to change to a different radiator that can hold up!! I did call Ford Customer Service and filed basically like a product grievance. The Ford Rep said he has put the case in as replace at no charge. I guess I will see how they handle this!
  #34
Old 02-24-2014, 07:47 PM
Quote:
sorry to hear that.. yeah they quoted me right over 1900$ parts and labor till they found out i had ESP.. but the truck has been sitting at the dealer since Thursday waiting on parts. Good luck on this . and Hope they do change this to a cost free change just like they did the plastic oil pans..
  #35
Old 02-25-2014, 08:41 AM
FordService's Avatar
FordService FordService is offline
Official Ford Rep
FordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud of
...I guess I will see how they handle this!
Keep me posted, runtowin. If you'd like me to step in and help, just send me a PM with your full name, best daytime phone number, VIN, mileage, and servicing dealership. I'll check things out and see how I can assist.
Crystal
  #36
Old 03-06-2014, 06:49 PM
Smokeispower's Avatar
Smokeispower Smokeispower is offline
Smokeispower is starting off with a positive reputation.
I too thought I had the dreaded radiator leak. Coolant on the steering damper and center tie rod, passenger side. Turns out after a pressure test that it's one of the hoses at the water pump. Tech at the dealer says he sees more of them leak when cold (it's been COLD here) than when warmer. Anyway, secondary cooling system, and not enough leaked out to put the level below min, guess I was lucky to see it.
  #37
Old 03-26-2014, 08:51 AM
KINGRANCHJM KINGRANCHJM is offline
KINGRANCHJM is starting off with a positive reputation.
2012 ford f250 radiator leak
Quote:
Originally Posted by FordService View Post
Let me know what you hear from the dealership, apd966. Give me a shout via PM and I'll do what I can to assist; please include your full name, best daytime phone number, VIN, mileage, and dealership info in your message.
Crystal
fgfgasdfasdfasdf
  #38
Old 03-26-2014, 09:06 AM
asdfasdfasd
  #39
Old 03-26-2014, 10:22 AM
Crystal
fadfasdfdfasdfasd
  #40
Old 03-26-2014, 11:12 AM
Official Ford Rep
Quote:
Originally Posted by KINGRANCHJM View Post
...Please contact me ASAP
Hi Jacob,
I don't have the ability to make or receive calls; I suggest sending me a private message (PM) with your information. Additionally, I recommend editing your public post to remove your personal details. If you'd prefer to speak with someone directly, you can contact our Customer Relationship Center at 1-800-392-3673.
Crystal
  #41
Old 03-26-2014, 11:27 AM
Hi Jacob,
Crystal
hi crystal
ive been trying to send you a pm and i cannot find where to send it at ive looked pretty much everywhere and cannot locate it...i just took my truck to the dealership and dropped it off this morning to get the radiator fixed on it and they told me they trucks like this come in every week to get it replaced
  #42
Old 03-26-2014, 11:33 AM
hi crystal
crystal
just found out that i cannot send you a PM because i havent been a member for more then 10 days....is there any other solution for you to helping me out?
thank you
  #43
Old 03-26-2014, 01:44 PM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
Call customer relationship center. 1-800-392-3673
  #44
Old 03-26-2014, 02:25 PM
Official Ford Rep
crystal
thank you
Hi KINGRANCHJM,
As Hdslider mentioned, your best bet will be to contact the Customer Relationship Center for assistance. They can offer the same help that I can. Give them a call at 1-800-392-3673.
Crystal
  #45
Old 03-26-2014, 03:19 PM
Radiator Leak
I called Ford Customer Service. They put in a service complaint and the very next morning the area service manager called me. He told me they pay for half of the replacement cost. It ended costing me $750 and the new radiator has a 2 yr warranty. I have since purchased the Extended Service Plan.
2004 Navigator slight coolant leak MackGuy 1997-2006 Expedition & Navigator 38 01-04-2017 10:22 AM
overheating and bubbles in overflow bsetbuilding Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 12-12-2016 03:05 PM
coolant dye tracer in a 6.0 05F250DSL 6.0L Power Stroke Diesel 12 04-30-2015 07:36 PM
COOLANT LEAK WRABER 6.0L Power Stroke Diesel 1 03-31-2015 12:52 PM
sprung another fuel leak woodtrucker 1994.5 - 1997 7.3L Power Stroke Diesel 2 03-04-2014 07:00 PM
Tags
2011, 67, 67l, anti, antifreeze, coolant, diesel, engines, f250, ford, freeze, leak, leaking, leaks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
