transmission availibilty - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-28-2011, 04:34 PM
fordtruck52 fordtruck52 is offline
fordtruck52 is starting off with a positive reputation.
transmission availability
as soon as i find my replacement ill let you know. i should be able to send just the case.
  #32
Old 07-28-2011, 04:41 PM
hey 52 f1 just a couple of more questions. given that the transmissions are the same and will bolt up to a flathead v8, would an adapter plate from speedway work to put in a t5 from an s10. i know that putting an early ford transmission will require only a little work and the t5 somewhat more but im only asking for future reference. my shop manual shows both three speeds and all of the 4 speeds. all except the light duty three speed have the clutch housing bolting up to the transmission with the same six bolt pattern. i think that the three speed i have a line on is a light duty floorshift. its in a 50 f1.
  #33
Old 07-28-2011, 05:07 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
I am not knowledgeable on the t5s. Sorry, I know there are several people who are though.
  #34
Old 07-28-2011, 09:08 PM
thanks a lot 52 f1 you have helped me a lot. i removed my transmission and will take it along when i find another (to set side by side and make sure it will fit). one other question though. other than shifting a transmission through the gears and turning the mainshaft what other things should i be looking at? and do you think a light duty three speed floor shift would be ok? thanks again
  #35
Old 07-28-2011, 09:25 PM
I would take the top off of the case and take a look for any issues chipped gears or a ton of wear. Those things were pretty tough for their size. As long as you are not pulling anything heavy I would not think twice about it.
  #36
Old 08-13-2011, 09:34 PM
hey 55 350, give me a yell back if you find something up in you neck of the woods. almost got this thing mechanically ready, just need the trany. i would hate to go to a t5 conversion and have to cut the floor plate. thanks again for the help.
  #37
Old 08-14-2011, 06:22 PM
hey old dan, could you take some pics of your trans and e mail them to me, maybe we can do business if i can find a way to ship it . fordtruck52@yahoo
  #38
Old 08-15-2011, 11:43 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Sure....I'll send you a PM. I'll snap a couple pics tonight.
Dan
  #39
Old 08-15-2011, 11:20 PM
dan. my e mail is fordtruck52@yahoo
Transmission output shaft leak? 52flatheadf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-07-2015 01:18 PM
52 f1 transmission 52flatheadf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 08-31-2015 04:36 PM
'52 car flathead V8 into 1953 F100 hoss73ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 06-11-2015 05:59 PM
'51 - '52 transmissions alamartina 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-24-2013 01:12 PM
transmission compatibility fordtruck52 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-10-2011 01:44 AM
Tags
1962, 223, bellhousing, clutch, duty, floor, ford, gear, light, manual, original, shifter, small, speed, spees, spur, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
