transmission availibilty - Page 2 - Ford Truck Enthusiasts Forums
Old 07-25-2011, 03:33 PM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
i sent you a visitor message or whatever it's called , norm has them still just gotta locate them in his storage lot , said 100 bucks for one if your interested . the 3 speed i got is laying under my bench , don't have a clue bout value , but i like to trade things too . so give norm a couple of days and i should hear again from him , and or if you want the light duty 3 speed we can figure that one out too . i gotta renew my membership as all these ad's are distracting me ..............
Old 07-25-2011, 09:41 PM
fordtruck52 fordtruck52 is offline
fordtruck52 is starting off with a positive reputation.
transmission availability
55, appreciate it. if the t 98 is good and will fit behind my 215 tell norm he has a deal. give me a call when he finds it 618) 588-3889
Old 07-25-2011, 11:45 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
If the t98 is 53 or newer it will not work because those transmissions have no rear mount. In 53 they went to bellhousing mount. Now if you were to find one of those rare 52 and older t98s it will bolt right up, but you will run into drive shaft length issues because the t98 is longer. What you really need (for simplicities sake) is a regular 52 and older 3 speed floor shift. I know the mounts between the 4 speed and 3 speed are different because of crossmembers, but take the mount off of the 4 speed and put it on the three speed. It will bolt right up.
Old 07-26-2011, 12:53 PM
thanks 52 f1. i have a line on a 3 speed floor shift in a 50 f1 with a flathead six. i havent made all the measurements to see if it would fit. my goal is to end up with an f1 with an 8 foot bed. so far so good the transmission is the only part left to complete then its paint and seat cover.
Old 07-26-2011, 01:04 PM
It will bolt right in. If you need a rear mount, let me know I have some. It should be the same as your spur gear 4 speed though.
Old 07-27-2011, 08:57 AM
55 f350's Avatar
they're out of a 55 f350 and a 56 f600 i had around here so there is no rear mount . you'd have too make a horseshoe shaped one like i'm gonna do as i dont like that beast hanging by 4 bolts off the bellhousing . so if you are still interested great , if not no biggie . my old 49 f4 is residing down the road from you in stonington working on a farm again . i thought he was going to replace the tranny in it with a newer od unit , but i'm not sure , and i'm also not sure now if it was a synchro 4 gear or not . i'll try and raise him and see .
Old 07-27-2011, 09:31 AM
hey 52 f1 a couple of questions. so the three speed will bolt right up to my 215 even though its now behind a flathead six? do i use my bellhousing and clutch and bolt it to the 3 speed case? also when i remove the old spur gear trans, do i unbolt at the engine block or the "clutch ring". i have decided to remove the transmission and take it with me when i find another to compare side by side.
Old 07-27-2011, 09:36 AM
hey 55, let me know about the 49 4 speed. it it isnt a spur gear i would be interested. in regards to the other transmissions i will probably drive up and look at them (if they are syncro) and bring mine for comparison. you have my number thanks
Old 07-27-2011, 10:37 AM
john fin john fin is offline
john fin is starting off with a positive reputation.
4-speed
I am interested in a 4-speed spur gear if any of you guys in the deep south have one. Mine has a cracked case.
Old 07-27-2011, 01:31 PM
i have a good spur gear 4 speed that you can have for a song after i find a syncro replacement. im in illinois the song doesnt have to be good
Old 07-27-2011, 01:33 PM
hey 55, i removed my transmission today and put it in my s10. that way i can bring it along and compare. if that three speed you have is a floor shift and doesnt look too bad we can make a deal on that.
Old 07-28-2011, 04:34 AM
55 f350's Avatar
my light duty 3 speed also is a 53-55 truck transmission so no rear mount , was a column shift but had been converted too a floor shift by the p.o and i'll be dained if i remember who but someone here ended up with the fenton floor shifter off it . i have a good , and i mean perfect long tailshaft car 3 speed with a rear mount but i'm kinda hording it for the 52 in case i need it . the t98's are a non synchro first gear , but 2nd through 4th are synchro . the 49 trans in question is a non-synchro and he hasnt pulled it out yet { he's a farmer and a wee bit busy } to start trying to swap the np 4500 into it . kinda waiting to see if he accomplishes that as my old 49 was a flathead v8 also and if he gets it done it could be quite useful info too those of us wanting a stouter trans for ours . i wil give you a call as soon as i hear from norm . he's been cleaning out his lot of the scrap { including a 67 toronado } and hauling it off so we shall see if he still has them . like i said he says he does . by the way my name is kevin so if you get a strange call { 217-691-3014 } it will be me .
  #28
Old 07-28-2011, 09:30 AM
I have a spur gear case from one I gutted a few years back if you want it. It is yours if you pay shipping. (It should not be too much depending on where you are located)
Quote:
  #29
Old 07-28-2011, 09:32 AM
All those transmissions were the same. Flathead 6 OHV 6 Flathead 8 will all interchange without messing with the bellhousing. The input shafts are even the same size and spline count.
Quote:
  #30
Old 07-28-2011, 10:12 AM
tranny
fifty-two_f1 - Those things weigh as much as my mother in law(a ton). I really just need the case. can you gut it and send the case. email me on this site so we can set it up. THanks.
Transmission output shaft leak? 52flatheadf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-07-2015 01:18 PM
52 f1 transmission 52flatheadf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 08-31-2015 04:36 PM
'52 car flathead V8 into 1953 F100 hoss73ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 06-11-2015 05:59 PM
'51 - '52 transmissions alamartina 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-24-2013 01:12 PM
transmission compatibility fordtruck52 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-10-2011 01:44 AM
Tags
1962, 223, bellhousing, clutch, duty, floor, ford, gear, light, manual, original, shifter, small, speed, spees, spur, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
