1951 F1: VIN & Chassis # and other infos for a rookie - Ford Truck Enthusiasts Forums
Old 07-11-2011, 06:12 AM
moidan moidan is offline
moidan is starting off with a positive reputation.
hello!
first of all - sorry about my bad english
my name is daniel, iam from austria, 35 years old, a big ford classic car fan and since 30 days the owner of a
1951 F1 Pickup
226 cui
GVWR: 4700 lbs
engine #: 7HA6050-C2
on the following pic you see my
- my friend jackson
- my daughter laura (4yo)
- my son noah (6 month old)
- me
current i also owned a 68 mustang
now i must collect the following information for the agency here in austria to get the license for my f1:
- axle load limit
i only have the curb weight (front 1860 lbs, rear 1360 lbs) without the payload (1.480 lbs). but i must know, how much of the 4700 are on the front and how much are on the rear.
maximum speed
yes this is correct - the agency need the maximum speed from the f1
and now my "big problem" - the VIN:
the vin on title is:
F1HIC15A85
and on the car (firewall passenger side) i found following #:
F1HIKC15485 - what kind of number is this?
where on the vehicle is the vin located?
PLEASE HELP ME
thanks very very much
warm regards,
daniel
ps. The authority needs documents to check information.
Old 07-11-2011, 09:27 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Daniel,
Welcome to the board.
Your government really demands a lot to register a vehicle. Unfortunately, I don't have the answers to your question, other than the VIN, it's the number you got off the firewall. The "K" might have been a misstamp, these old Fords aren't known for having a high standard of quality control on the assembly line. As for top speed it's only a guess, depending on the engine and transmission, but I would say 50-55 mph is a comfortable top speed for a stock F-1 with a V-8 and 3 speed transmission.
I am sure there will be others jumping in with the answers you're looking for.
BTW, you have a really beautiful truck, yes, even though it has a manure spreader grill.
Old 07-11-2011, 10:53 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Hi Daniel,
Welcome to the forum! That is a beautiful truck, and a wonderful family you have. Thank you for sharing your photos.
It looks to me as someone mis-read the VIN at some time and mis-typed the information on your title. The number on the plate sounds correct for your truck. It decodes as;
F1 = half ton pickup (F-1)
H = 226 6 cylinder engine
1 (I) = 1951 (Ford stamped I for the number 1)
KC = Kansas City assembly plant
15485 = the consecutive unit number
You can see the similarities between the title and your data plate, where they left off the K, and transposed the letter A for a 4.
If you look on the top of the frame rail on the right side (passenger side) under the hood near the motor mount, you should find the VIN frame stamp there. Lets hope that matches your other numbers.
I hope this helps.
Old 07-11-2011, 10:57 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Daniel - My welcome too. Below are Ford documents that I believe give authoritative answers to your questions. First is from the Ford Truck Chassis Parts and Accessories Catalog, 1948-1954. I scanned the cover for your government agency to see that it is an official document, and scanned the page that describes the 1951 VIN/Rating Plate data explanation. The data plate pictured might not look exactly like the plate that should be attached to your glove box/dispatch box door. As explained on the page, Ford changed the plate design in the latter part of 1951. The data, however, will be the same. The VIN is, as Bob and Wayne have said, the F1H1KC15485. You will find that number stamped into the frame rail on the right/passenger side inside the engine compartment. Normally it is located near the engine mount cross member.
The next three scans are from the 1951 Ford Truck Handbook. It is a dealer or salesman's guide that is not a commonly available reference. I scanned the cover page for your government to see the 6-1-51 publication date. Also scanned is the Load Capacity Chart that gives axle weight ratings, 2,500 pounds front and 3,000 pounds rear. Last is the Performance Table that gives maximum speed for each model and engine/rear axle combination. If you have a 3.92/1 rear axle ratio it shows top speed 64.8 m.p.h., or 59.6 m.p.h. if you have the 4.27/1 ratio. Hoping these documents satisfy your governing authority. If more information is needed, please say. Stu
Old 07-11-2011, 11:39 AM
great - its realy great
thanks very much to all for the excellent infos in this short time
iam at the ride place
here are some pics of the vin
firewall:
frame rail:
titel:
insurance identification card:
It looks realy that someone mis-read the VIN at some time and mis-typed the information on the title.
how can i get a title with the correct vin? is that possible?
thanks so much,
daniel
Old 07-11-2011, 12:08 PM
stu,
many thanks for your efforts.
one question about the axle rating:
why are the total (front and rear) 5,500 lbs and the GVW only 4,700 lbs?
I think the authorities want to be satisfied with the documents.
@wayne
thanks for decoding the vin
daniel
Old 07-11-2011, 01:24 PM
The individual axles would have been rated for more than their share of the total GVWR. Sort of like being over constructed.
As for getting a corrected title, in the US it wouldn't be hard. At least in my state, I'd have to have a law officer inspect the truck and certify that the change was warranted. In your case it's hard to say. I'd suggest getting guidance from your authorities. Stu
Old 07-11-2011, 03:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Beautiful truck! Wlecome to the forum!
I have a similar situation with a motorcycle over here. The title is correct in every regard except it says "1965" when the VIN decodes to a '69. Based on many things, it is truly a '69, but someone back when everything was done on paper typed the wrong number. I've been to the State DMV and they went back as far as they could, and found it said '65 all the way back to the '80's when they computerized. So it "clearly" wasn't their mistake, and basically said, screw you (me).
Over here you can get a completely new title, as a "special construction", or a bonded title which means you buy title insurance in case someone later comes along to say it's theirs. Make friends with your local officials, it will pay off. Or if you are an Automobile Club member, see if they can help.
Old 07-12-2011, 12:53 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Nice looking truck!
When you get the title issue straightened out, you may want to replace the hood side moldings with the correct 1951 moldings. Your current moldings are from a 1952 model and are different than 1951 moldings.
Old 07-13-2011, 01:49 AM
Where do you buy the spare parts for your Trucks?
Old 07-13-2011, 11:58 AM
Moe Craig's Avatar
Moe Craig Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
First, welcome to the FTE! When I bought mine, I found an error with the title. I had to have an inspection done on the my truck. Then I had to take the report and the title to my DMV and they issued a new title with the corrections.
Old 07-17-2011, 08:32 PM
KOMBILOVE's Avatar
KOMBILOVE KOMBILOVE is offline
KOMBILOVE is starting off with a positive reputation.
MOUlDINGS FOR 51
Quote:
Originally Posted by 51PanelMan View Post
Nice looking truck!
would you have photo of moulding for a 51 truck,,please,,,as i have those mouldings as well,in my 51,,,many thanks
lorente@btinternet.com
london uk
Old 07-17-2011, 11:53 PM
51PanelMan's Avatar
london uk
This is the correct 51 hood molding (non 5 Star Deluxe).
Just for reference, this is what a 52 molding looks like.
I have several sets of the 51 hood side moldings. PM or email me if you're interested.
Old 07-18-2011, 02:24 AM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
Nice 51 you got there !!! I ALSO have a 51 and a 67 mustang. WELCOME TO FTE.
Old 07-18-2011, 02:58 AM
Boom48's Avatar
Boom48 Boom48 is offline
Boom48 is starting off with a positive reputation.
Where is that frame rail Vin # spot located? im trying to locate the vin on my frame rail on what i thought was my 48 ford panel everyones telling me its a 51....
Expedition Lost Coast - Sept 19-20 M3dragon N. California Chapter 5 10-25-2015 11:09 PM
GREETS FROM AUSTRIA/ EUROPE HarleyTom New Member Introductions 1 07-10-2015 07:45 AM
New Member from Austria Paost New Member Introductions 1 11-01-2014 07:01 AM
Newbie; 66 F-250 Camper Special (with a few pics) Pleffnut 1961 - 1966 F-100 & Larger F-Series Trucks 11 12-28-2012 09:57 AM
Problems with Engine!? 1951 F1, 226 cui moidan 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-28-2011 11:19 AM
Tags
1951, card, decode, empty, f1, f100, ford, indentification, insurance, location, pickup, vin, vins, weight, wi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
