Rear view camera - random problem - Ford Truck Enthusiasts Forums
Old 07-10-2011, 11:01 PM
DrewF's Avatar
DrewF DrewF is offline
DrewF is gaining momentum as a positive member of FTE.DrewF is gaining momentum as a positive member of FTE.
I picked up my new truck last Friday, and already the rear view camera is having a problem.
Sometimes it comes on, and is all fuzzy and black and white.
Other times, it comes up solid blue, then the display goes off.
Guess I'll be making my first trip to the dealer.....but it wont be the selling dealer, as they are about 70 minutes away.
Anyone else had this issue? I did a quick search, and nothing came up.
Old 07-10-2011, 11:36 PM
nebmike's Avatar
nebmike nebmike is offline
nebmike is starting off with a positive reputation.
I've had mine about six weeks now, and have experienced the same exact thing. In addition, I've had times where it wouldnt shut off when going from reverse to drive -- it would stay on until I shifted into park.
I'm not too concerned about it, so I'll just wait until I need to be at the dealership for something else...
Old 07-11-2011, 07:22 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Best option is to visit your dealer for this one.
Also if you're concerned about whether or not you'll be able to reproduce the issue at the dealer, take a video of what happens so you'll have that if you need it.
Old 07-11-2011, 07:26 AM
DrewF's Avatar
Yeah, I have already taken photo documentation of the issue. This way the dealer tech knows I am not making things up.
Old 07-11-2011, 02:01 PM
doczenith1's Avatar
doczenith1 doczenith1 is offline
doczenith1 is starting off with a positive reputation.
Mine has done the b/w fuzzy a few times as well. Seems like it happens when its hot out and the camera has been in direct sunlight for a while. Out of curiosity, do you guys have the NAV system or standard radio? I have the standard radio.
Old 07-11-2011, 02:19 PM
DrewF's Avatar
I have the standard radio too.
Old 07-11-2011, 03:12 PM
nebmike's Avatar
Quote:
Same here.
Old 07-11-2011, 07:05 PM
carpbob's Avatar
carpbob carpbob is online now
carpbob is starting off with a positive reputation.
Have you taken the tailgate off for line-x or anything? If so check the plug.
Old 07-11-2011, 07:21 PM
DrewF's Avatar
Not yet. I'll probably check the plug. It seems to work after I open/close the tailgate. I checked the wire where it comes out of the bed and into the tailgate, but it looks fine.
Old 07-11-2011, 08:56 PM
Double-Trouble's Avatar
Double-Trouble Double-Trouble is offline
Double-Trouble is starting off with a positive reputation.
I would take the cover off the tailgate and check for a loose ground. If I didn't want to take it to the dealer.
Old 07-18-2011, 08:14 PM
cabindoc's Avatar
cabindoc cabindoc is offline
cabindoc has a very good reputation on FTE.cabindoc has a very good reputation on FTE.cabindoc has a very good reputation on FTE.
You might also try taking the radio out and check the connection to the back of the radio.
Old 07-19-2011, 05:18 PM
grantschim's Avatar
grantschim grantschim is offline
grantschim is starting off with a positive reputation.
I've had my 2011 for several months and the rear-view camera has worked flawlessly. I have the Nav System.
Old 07-19-2011, 05:50 PM
2horses's Avatar
2horses 2horses is offline
2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.
Mine has been flawless with the NAV system - maybe it's more of a display issue than a camera issue? Since all of y'all that are having the same problem have the same rear view mirror display, it could be the problem instead. Maybe it's heat related.
Old 07-19-2011, 07:08 PM
lkbrow1 lkbrow1 is offline
lkbrow1 is starting off with a positive reputation.
The wiring to the camera video is a coax cable. Right before the plug that allows you to disconnect the tailgate the coax is spliced back to regular wires that go into the connector. You could have an intermittent connection there. If the video signal is weak the display will remain blue until it times out then goes blank. If a video signal is strong enough, the camera stays on after shifting into drive until you reach a minimum speed. I can back out of my drive way, pull up to my mail box, read a letter, and the camera will stay on until I leave the mail box.
I removed my tailgate and connected a camera to the harness that was in a license plate holder.
that's how I got so familiar with the functionality.
Old 07-19-2011, 10:50 PM
Painted Horse's Avatar
Painted Horse Painted Horse is online now
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
"I removed my tailgate and connected a camera to the harness that was in a license plate holder. that's how I got so familiar with the functionality."
Did your license plate camera plug into the harness or did you do a splice. I've been wanting to add a camera on the back of my trailer for when I back into dark spots when days get shorter.
Camera Views...Front Camera...Can't get it to work WolfFox 2017 Super Duty 10 11-22-2016 10:43 AM
Rear view camera wiring assistance request. jonrjen 6.7L Power Stroke Diesel 26 10-30-2016 03:03 AM
Aftermarket review camera option CJF350 1999 to 2016 Super Duty 17 01-11-2016 11:31 AM
OEM Navigation and back up camera kdokey 2007 - 2014 Expedition & Navigator 0 03-17-2014 02:12 PM
Ford Nav upgrade problem with back-up camera video? mmoore7038 1999 to 2016 Super Duty 1 08-12-2012 03:34 PM
Tags
150, 2008, 2011, bug, camera, f150, f350, ford, issue, problems, rear, rearview, superduty, view, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
