Monroe Steering Stabilizer Install Assistance
Old 07-10-2011, 10:12 PM
CS45's Avatar
CS45
CS45 is offline
Good Evening All
I installed my new Monroe Gas Magnums with little trouble on Saturday. Had a look at the Monroe Item # SA1943 Steering Stabilizer kit and it's not making sense to me.
Wondering if anyone has installed this single kit and if you have some pics to share, or pointers.
Regards
CS45
Old 07-11-2011, 03:13 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I have the Monroe gas magnum shocks on my truck as well, and really like them.
As for the steering stabilizer, I have a Monroe shock mounted to Rancho brackets. I bet its similar. I looked up your part number and the brackets do look a little different. I have seen kits like that as well. They mount similarly to mine. One side has U bolts that grab on to the passenger side steering linkage and the other side mounts to the bottom of the crossmember and requires a pair of holes drilled in it. If you have the power steering line that runs there, make sure you bolts don't interferre with it.
Did you kit not come with instructions? Here is a picture of mine, that may help you.
Old 07-11-2011, 11:39 PM
CS45's Avatar
CS45
CS45 is offline
Ya, the directions are poor to comprehend, I think the heavy bracket mounts to the pssenger side box frame and the other side like you got it on the steering linkage.
They're directions leave something to be desired, in this day of the ease of information transfer.
Anyone on here with this setup and a pics for me would be greatly appreciated.
CS45
Old 07-12-2011, 10:23 AM
White Max's Avatar
White Max
White Max is offline
CS45
Sounds like it mounts up the same as the Superlift kit.
CS45
04-03-2015 07:07 PM
chrismd188
02-14-2014 09:11 AM
donsabi
Escape & Escape Hybrid
20
12-30-2012 03:41 PM
cgi2099
01-31-2012 08:55 PM
jcbx
03-03-2008 10:37 AM
Quick Reply: Monroe Steering Stabilizer Install Assistance
