Increasing hydraulic line pressure in the E40D?
E4OD doesn't lock its TCC until 3rd gear, under light power or steady speed. Back on the throttle moderate to heavy will unlock it again.
It will unlock/lock during the shift to O/D.
Changing the thermostat will not clear limp mode, disconnecting the battery will but if problem isn't corrected will enter limp mode again in a very short time.
As suggest best place to start would be run KOEO self test to begin troubleshooting it, could be something as simple as a damaged wire under the truck.
LARIAT 85
'80-'86 HOWTO's
28
07-07-2022 03:50 PM
axidjw
07-20-2017 11:35 AM
pilot47
10-31-2016 01:55 PM
Encho
03-03-2016 02:45 PM
66f100prostreet
10-29-2009 12:03 PM
1920, check, e40d, ford, hydrolic, increase, increasing, line, pressure, replacement, spec, test, transmission, truckhydraulics, upping
