Transmission line removal from radiator - Ford Truck Enthusiasts Forums
Old 11-19-2014, 07:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
Print Wikipost
Old 07-10-2011, 09:15 PM
mohle's Avatar
mohle mohle is offline
mohle is starting off with a positive reputation.
Ok, in the process of removing radiator and I'm wondering about the transmission cooler lines running into and out of radiator. Is there a special tool required for a 2006? I took off the plastic retainers, they just snap off, but the line looks sort of like a quick connect fuel line.
Old 07-10-2011, 10:46 PM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
Yes, you should use a disconnect tool like the ones used on fuel lines...
Along the lines of this, but should be able find one at a local auto store. Need a 1/2" one...
Ford Transmission Cooler Line Disconnect Set | OTC Tool Manufacturer for Cars and Trucks
Old 07-10-2011, 11:05 PM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
Be careful if those lines are rusty you may need to replace them.
Don't ask me how I know.
Old 07-11-2011, 12:15 AM
mohle's Avatar
No rust.
I've got fuel line ones in 1/2", but they are too long. They won't fit between the ridge on the line and the fitting. Had some shorter ones previously, but they have gone the way of the dodo bird. Guess I'll have to leave it for tomorrow. Rads got to come out for a proper cleaning.
Old 07-11-2011, 12:32 AM
sammy77's Avatar
Yes you definetley need the exact tool for the job. Close won't work for those
Old 07-11-2011, 02:17 AM
mohle's Avatar
Just did a search for a disconnect tool. Lisle makes a complete kit. Funny, there is a whole bunch of generic ones included, but of course there is also a Ford specific transmission line tool.
2002 F-350 Radiator Replacement Whitey Ford 1999 - 2003 7.3L Power Stroke Diesel 16 12-04-2016 02:21 PM
transmission line hookup Ben24 1987 - 1996 F150 & Larger F-Series Trucks 2 09-06-2013 12:59 PM
OTW Transmission Leak jimbouy 1999 to 2016 Super Duty 0 08-18-2012 11:46 PM
Bad radiator cause this? rickybobby1977 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-22-2011 02:08 PM
Transmission line removal blowin smoke 2004 - 2008 F150 1 06-18-2011 12:47 PM
Tags
06, 2005, 60, cooler, excursion, f350, ford, install, line, lines, radiator, removal, tool, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
