rear a/c warm - Ford Truck Enthusiasts Forums
rear a/c warm
Old 07-10-2011, 06:29 PM
MontanaBighorn MontanaBighorn is offline
MontanaBighorn is starting off with a positive reputation.
rear a/c warm
2005 X limited, 84000 miles V10. bought the X a month or so ago for $18,000 OTD. everything is beautiful except that the rear A/C is warm. i work in commercial refrigeration so i should be able to handle the repairs myself, but i dont know how the system is designed to work. is there a solenoid in the line-set leading to the rear vents and if so, where is it hidden? i havent even begun to try to diagnose anything yet; i want to get the system specifics first.
thanks,
Old 07-10-2011, 07:42 PM
6686L 6686L is offline
6686L is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by MontanaBighorn View Post
. . . . the rear A/C is warm. i work in commercial refrigeration so i should be able to handle the repairs myself, but i dont know how the system is designed to work.
Your honesty MAY get you on the right track = Late news flash. Your FORD/s A/C system has little relationship to the typical commercial system!
It is a computer-controlled NIGHTMARE. During assembly, when the truck was wired, there is a bunch of wires underneath the right-hand rear window revel, that often has one or more "shorts" or "breaks" in it. You can start there.
If that dosnt disclose something obvious, STRONGLY recommend you find a COMPETENT Ford dealer and take it there. The system is not for the ordinary refrig. tech. (been there...done that....!)
Old 07-10-2011, 08:29 PM
Shepherd2 Shepherd2 is offline
Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.
A few people have had sucess replacing the TXV.
http://www.techchoiceparts.com/ShowI...#ItemNotes1Div
Old 07-10-2011, 08:59 PM
2003u45 2003u45 is offline
2003u45 is starting off with a positive reputation.
in the rear a/c is an expansion valve that sticks. that is your problem, an inexpensivce fix. check it out. i just had thge same thing. my compressor took a crap. replaced and they blew out the front lines but not the rear. 2 weeks later rear quit. was ewxpansion valve. now I have another problem. requires a question to all..
Old 07-12-2011, 12:17 PM
thanks for all the responses. is there anything available online showing me the location of all the components at least?
6686L,
if i associate an unfamiliarity of system specifics with inability to repair equipment i would have been out of business looong ago. theres nothing complicated about it once you have the system specs, and over the years ive found that it will never get repaired if you dont start turning wrenches. besides, i would just feel dirty paying someone else to do what i do. ;-)
Old 07-12-2011, 01:41 PM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
6686L,
I think you'll find everything after removing the rear panel, very basic systems!
BTW, I've worked on cascade refrigeration systems for over 20 years and know nothing is more basic than an AC system.
Old 07-12-2011, 01:42 PM
fgials's Avatar
fgials fgials is offline
fgials is starting off with a positive reputation.
Just replaced the expansion valve in mine and mine works Great! It is in the right rear panel behind the jack.
Old 07-12-2011, 05:37 PM
Sader's Avatar
Sader Sader is offline
Sader has a good reputation on FTE.Sader has a good reputation on FTE.
Amen to that!
Old 07-12-2011, 05:55 PM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
The expansion valve is behind the jack door compartment. You have to pull the rear passenger panel enough to remove the black plastic compartment. It is right behind there, brass in color with two lines in and two lines out. Torque the lines to 15ftlbs. when you reinstall.
I believe the black plastic jack compartment is held in with one plastic rivet near the top front.
To get to it,
1) Pull out the rear seat.
2) Unscrew the floor mounting plate for the rear passenger seat belt (large torx bit)
3) Remove passenger panel from the rear.
(At this point, you should only have to peel the large rear panel away by about a foot if you are willing to work in a tight space, otherwise, remove the whole side panel.)
4) Remove plastic rivet and jack compartment
Napa and Orielley both list the part as order in...unless you have an Napa warehouse nearby. Rockauto has the valve the cheapest.
Old 07-12-2011, 05:57 PM
[quote=MontanaBighorn;10565740] . . . . . theres nothing complicated about it once you have the system specs, . . . .
THAT'S THE PROBLEM. WHILE BASIC REFRIGERATION ISSUES CAN BE EASY TO REPAIR.....WITHOUT THE SPECS. AND ACCESS TO THE 'PROPRIETORY' PARTS...WELL.....!
BE ASSURED I KNOW THAT FEELING. I HAVE TWISTED A WRENCH OR TWO OVER THE YEARS MYSELF. (AND I TRULY HATE IT WHEN I RUN ACROSS A SYSTEM OBVIOUSLY DELIBERATELY DESIGNED TO TRY AND FORCE YOU TO GO TO A MFG'S REP / DEALER....!
Do you remembe a line from a Clint Eastwood movie..." MAN'S GOT TO KNOW HIS LIMITATIONS".....!
Old 07-12-2011, 09:24 PM
Sader's Avatar
I think what MontanaBighorn is getting at is the A/C system on the excursion is a basic system, nothing special. The controls are the hard part. We field repair guys have to have the attitude we can and will fix anything, if we come across a new system, building, customer we have not seen before we cannot shy away from it just because of proprietary parts or controls. A human put it together and a human can figure it out.
Automotive A/C is less complicated then many items I or any other tech on this forum has probably experienced. Taking time to figure out Ford's system controls may be a hindrance but will be overcome.
Cheers
Old 07-13-2011, 09:29 AM
Forest's Avatar
Forest Forest is offline
Forest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to behold
Before you open up the R134 system to put in the new expansion valve, make 100% sure that the electric blend door motor is working. This relatively simple part was the reason that my rear heater quit working. Maybe your problem is the opposite(?) Maybe the blend door is "stuck" giving you heater core air in large enough quantity to make you think A/C is not working(?)
This motor and blend door will be readily visible once you remove the passenger side rear panel.
On another level, you may also want to "feel" the refrigerant lines coming to/from the rear evaporator. If the exiting line is cold, then the expansion valve may be OK.
Old 07-13-2011, 12:51 PM
Quote:
indeed. i do THIS every day...if i get intimidated by the a/c in my X then im already as good as done for.
...can anybody tell me if the OEM part has been redesigned to prevent this apparently known issue? if it has been redesigned i will go with an OEM TXV, but i dont want to replace a known failure with the same old known failure.
thanks!
Old 07-19-2011, 03:40 PM
thanks for the information. i picked up a TXV at napa for $48, and it only took about an hour to change out. the only difficult part about it is getting the flare fittings tight in the limited space. rear A/C cooling great now!
Old 07-19-2011, 04:13 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is online now
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Thanks for posting the outcome - that seems to be the most difficult part
somtimes, finding out what fixed it (or not).
Love that BigSky Country.
Welcome to FTE!
A/C and Heater on at the same time hotfalcoon 1997-2006 Expedition & Navigator 14 12-04-2015 06:13 PM
a/c not working hotrodhippi 1999 to 2016 Super Duty 12 12-06-2013 03:46 PM
2002 navigator rear a/c blows cold then warm jeffrey5679 1997-2006 Expedition & Navigator 2 05-08-2013 10:29 AM
Rear A/C leak on 2000 E-350 Rick E-350 V-10 1968-2013 Full Size Vans 3 08-18-2011 07:56 AM
99 A/C working pressure? Selkirk 1997-2006 Expedition & Navigator 1 07-03-2011 03:00 PM
Tags
2003, 2005, 2006, ac, e150, excursion, expansion, ford, mountaineer, rear, replace, txv, valve, warm, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
