Coolant Meeting CAT EC-1 - Ford Truck Enthusiasts Forums
Old 07-10-2011, 12:40 PM
cajunsuperduty's Avatar
cajunsuperduty cajunsuperduty is offline
cajunsuperduty is starting off with a positive reputation.
I was wonding who manufactures alternative coolant recommended in the tech folder coolant flush section. (coolant meeting CAT EC-1) Where can I buy it? Is this something that is available at most Auto Parts stores i.e. O'reily.
Old 07-10-2011, 01:01 PM
rdunagan's Avatar
rdunagan rdunagan is offline
rdunagan is gaining momentum as a positive member of FTE.rdunagan is gaining momentum as a positive member of FTE.
not really i had to order mine from cat but i think someone said NAPA carries a brand of it i cant remember what its called though
Old 07-10-2011, 01:07 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
heres what I got from oreilys best of all it was silicate free
http://www.finalcharge.com/
click here^^^^^^^^^
it wasnt letting me post it right it was a couple bucks cheaper than the gold
The FINAL CHARGE Formula - Globally Tested
Old 07-10-2011, 02:15 PM
73stang's Avatar
73stang 73stang is offline
73stang is starting off with a positive reputation.
Well there is
Shell Rotella ELC
Dello ELC
CAT ELC
Zerex ELC
I'm sure these all meet CAT EC-1. I picked up some Rotella ELC at a truck stop. You could try that or try going to a CAT dealer directly.
Old 07-10-2011, 02:34 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
Preston also makes a ELC that meets CAT EC-1. As well as the stuff internation uses (can't remember the name of it right now).
Old 07-10-2011, 03:26 PM
BLADE35's Avatar
Quote:
fleetrite or fleetgaurd or somethind like that I remember it was also silicate free
Coolant Temp and Oil Temp Delta JamesMcMn 6.0L Power Stroke Diesel 13 10-17-2016 10:47 PM
Amsoil CAT EC-1 Coolant ? jeremiah77 6.0L Power Stroke Diesel 2 08-08-2015 12:51 PM
Coolant help TinMan289 6.0L Power Stroke Diesel 3 05-30-2014 02:41 PM
Another Coolant Question troy676 6.0L Power Stroke Diesel 14 03-25-2014 10:43 AM
Mobile Delvac Extended Life Coolant MPlayer 6.0L Power Stroke Diesel 5 05-31-2011 11:20 PM
Tags
60, brands, cat, caterpillar, combatilibe, coolant, ec, ec1, elc, elc1, fleetrite, ford, list, rated, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
