7.3 connecting rods - Ford Truck Enthusiasts Forums
7.3 connecting rods
Old 07-10-2011, 12:20 PM
glenntorinosport glenntorinosport is offline
glenntorinosport is starting off with a positive reputation.
7.3 connecting rods
Having had a 2000 F-350 lariat PSD crew cab ,I read somewhere about the conncting rods for this engine some were forged and others were the compressed iron , it mentioned about serial #'s Does anyone know which ones had the forged rods ? thanks for any help Glenn
Old 07-10-2011, 01:51 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 07-10-2011, 03:10 PM
Robert6401's Avatar
Robert6401 Robert6401 is online now
Robert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to all
Im fairly certain that with the 2000, you have forged rods, so you lucked out. Someone with the serial #s should come along and be more specific, but I think they started with the powdered metal rods sometime in 2001.
Old 07-10-2011, 03:15 PM
Farmboypowerstroke Farmboypowerstroke is offline
Farmboypowerstroke is starting off with a positive reputation.
Quote:
99's and 2000's had forged, 2001 was hit and miss, 02 and so on had the powdered metal rods. Thats what I think, but don't hold me to it
Old 07-10-2011, 03:17 PM
ToMang07's Avatar
ToMang07 ToMang07 is online now
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Old 07-10-2011, 06:27 PM
cleatus12r cleatus12r is offline
cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.
I've personally seen one that should have had forged and didn't. I've also seen two the other way as well (one was this week). This was going by serial number.
The ONLY way to know for sure is to visually check. Seriously. Don't be lazy and assume based on a list of serial numbers or a model year......If you REALLY care, take the 10 minutes and check (the 10 minutes also takes into account the finding/making of a 5/16" square drive tool).
Old 07-10-2011, 06:44 PM
ToMang07's Avatar
*Cough* Write-up? *Cough*
Old 07-10-2011, 06:59 PM
2006lariat's Avatar
2006lariat 2006lariat is offline
2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation
Both of the rods in that writeup are Forged PMR's, I make them! One is just more Crudely done, and less finished than the other! I would agree the Crude lookin one, (the one with the line goin down the side of the shank) is probably stronger. PMR Rods as You guys know them, (the nice one on top) can be made MUCH stronger, but that all depends what international wants too pay!
Old 07-10-2011, 07:02 PM
ToMang07's Avatar
Quote:
Umm....
One is a Powered Metal Rod. (PMR)
The other is a Forged Rod. (NOT PMR)
They ARE both Rods...
Old 07-10-2011, 07:09 PM
2006lariat's Avatar
They are both forged! One is just more refined. The pretty one is forged a little differently. (actually better) The crude looking one, although "stonger" (which depends on material PM) is made with crude methods! I make these everyday! (Well not the 7.3ltr anymore) Again The Pretty one can be as tough as any, it depends what the customer is willing too pay! An example= The same rods used in a ford V6 (cant remember the exact engine right now) also go in a v10 or 12 (Idont remember, as I am not on that program anymore) aston martin. The difference is material. The astons are probably 3X's stronger, but are identical in everyother way.
Old 07-10-2011, 07:14 PM
ToMang07's Avatar
WOW dude....
PMR: Powdered Metal. Stamped, powdered metal.
Forged: FORGED Steel. Cast in a forge.
Do I need to clarify the difference? ITS THE TYPE OF METAL. Powered Metal vs. Forged. They are not made the same way, because they are made with different metals. Clearly not identical, put together differently, made diffferently, with different metals. I have no doubt you make aftermarket or rods for later engines... but the ones in the 7.3 are not the same, at all.
Old 07-10-2011, 07:16 PM
2006lariat's Avatar
Ok Dude. .
Old 07-10-2011, 08:45 PM
Actually, 2006lariat IS correct on some counts. Powdered metal rods (also called "sinter-forged") ARE forged.
Basically, it boils down to whether or not the metal is heated to it's absolute melting point or not.
"Forged" rods are poured into a cast as a liquid and then pressed using several thousand pounds. They are then cooled as a solid, forged piece of steel.
The powdered metal rods are constructed using fine metal powder and heated just enough to allow the particles to fuse together.
Yes, powdered metal rods ARE stronger and superior in many ways to their "forged" counterparts.....however, they are typically more brittle. This is why tuning plays a major part in how durable the PMRs are. Higher peak cylinder pressures can shatter the brittle rods that the more pliable "forged" rods can soak up for many more cycles.
Old 07-10-2011, 09:00 PM
I guess I may elaborate a little more.
I wouldn't call one process more "refined" than another. The forging process is a good bit different, but what happens to the connecting rod AFTER forging is quite different.
The "forged" rods are cast as two pieces. The main beam is produced separately from the cap of the "big end". The two halves of the big end are mated together (using a machining process), the rod bolts installed and torqued, the bore is machined, and then honed. At this point, the cap and the rod are a matched set. Then it's back apart to install in the engine. While it is possible to bolt another rod's cap on any of the other rods (and there will be little to no indication that it is incorrect), it is very possible to end up with journal clearances that are too tight, too loose, or just a bit off-center. The "forged" rods take a lot more machining to be correctly fit to a crankshaft journal.
The powdered metal rods are forged as one piece. Both ends of the rod are cast into the forging. The big end is machined and honed, bolt holes are drilled and tapped, and then the "big end" is broken in half. There is no way to install another rod's cap because the rough surface created by the break is privy ONLY to that connecting rod. It will be glaringly obvious that the wrong cap was installed on any particular connecting rod.
In addition, assembly of the engine is faster with powdered metal connecting rods (or ANY rod for that matter that uses capscrews instead of studs and nuts) because no assembly tools are required to keep the studs from nicking the crankshaft when the piston/rod assemblies are installed in the block.
By saving tons of time and machining processes involved in "forged" rods, the automaker (or engine maker in this case) can cut costs and production times while still offering a product that will operate as originally designed for the purpose for which it was meant.
Old 01-28-2012, 09:57 AM
Diesel and Steam's Avatar
Diesel and Steam Diesel and Steam is offline
Diesel and Steam is starting off with a positive reputation.
So if you have a 2001 how do you know which rods you have?
Connecting Rod recomendation. juancho_uy Ford Inline Six, 200, 250, 4.9L / 300 11 11-19-2015 09:12 PM
95 f150 5.0 with 1.7 rollers? does it have forged pistons? Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 6 07-14-2015 10:43 PM
Are EBU-A and C2AE the same type of forgings jimcar-9 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 03-20-2012 08:34 AM
THESE Rods: Forged or PMR??? ToMang07 1999 - 2003 7.3L Power Stroke Diesel 3 01-30-2012 09:24 AM
Disappointing Discovery on connecting Rods homesteader 1999 - 2003 7.3L Power Stroke Diesel 16 03-12-2010 04:11 PM
Tags
1999, 2000, 73, connecting, diesel, f250, ford, forged, installation, kit, metal, powdered, rod, rods, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
